Question about Husqvarna Sewing Machines
How to remove needle cover on husqvarna 2000 sewing machine
SOURCE: Needle doesn't move the problem isn't the foot pedal
Same problem with my 400. I took it in to dealer and they said main computer board on my machine would have to be replaced. Fortunately, they agreed to get it fixed for me. My machine is 2 years old. How old is yours? I wonder if this could be a manufacturer defect on the machine? Maybe this needs to be addressed with Viking Husqvarna Corporate.
Posted on Jul 24, 2008
  • 3 Answers
SOURCE: i need husqvarna 2000,model6020 manual
You can purchase a download or CD for your machine at #73 at this link:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Viking.htm
You can also order one from the following link:
http://www.sewusa.com/Sewing_Machine_Manuals/Viking_Manuals/6010_6020_Instruction_Manual.htm
Posted on Feb 02, 2009
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
  • 371 Answers
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
  • 152 Answers
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Posted on Oct 14, 2009
How do I obtain a husqvarna sewing machine 2000 SL maintenance manuel ?
Hello usually the machine has a name in its title also ie Husqvarna VIKING 2000SL. I typed your machine type into google and then clicked on images and found photos of the manual. You could just then print out the pictures or click on links for more info. You could go to www.sewingnz.com/husqvarna-viking-service manual. BUT THEY WILL CHARGE YOU $10 + POSTAGE. Try first idea for just price of printing it out. Good luck-
Aug 10, 2014 | Husqvarna Sewing Machines
How can I get the needle dropped into sewing machine?
remove the needleplate, turn the machine upside down and try to shake it out.
May 11, 2014 | Husqvarna Sewing Machines
How to put a thread cutter in husqvarna viking desinger se sewing machine
I believe the plastic cover (gray?) toward the end of the arm (left of the needle plate) is removable by prying (gently) on the front edge and sliding toward you. Unless the cutter is broken, you should be able to figure out how itall fits back together.
Dec 21, 2012 | Husqvarna Sewing Machines
I have a Husqvarna 936 huskylock which is about two years old. I have not used it much yet and yesterday I set it up to do a cover stitch for the first time. Since then I have spent hours threading...
For the cover stitch, only use a size 90 needle. Depending on the type of knit, use a ball point or stretch needle. The 936 uses standard sewing machine needles, so you can switch needles with the type of fabric, just like with a sewing machine.
Jun 29, 2011 | Husqvarna Huskylock Computerized 936
My machine will not stitch....have tried every combination and it keeps dropping stitches
Start with brand new needles. Make sure you use sharp needles for woven and ball point for knits.
Remove all threads from machine. Open all covers,, including top cover (under thread tension). Remove all lint. Oil moving parts. Replace covers.
Thread your machine from right to left. In other words, start with the lower looper, upper looper, right needle, then left needle. That should solve your problem. Thread must be threaded in specific order and through every loop in order to work. One miss threaded loop will cause the machine not to sew properly.
Apr 16, 2010 | White Sewing Superlock 2000 ATS Mechanical...
Needle severs thread each time I start sewing
Take the thread completely off the top of the machine. Put in a new needle. Remove the bobbin. When you rethread the top of the machine make sure the presser foot (that rests on the fabric) is in the "UP" position and rethread the top. Also when you thread the top, put some "pull" on the thread as you thread it, don't just lay the thread in the tracks. You need to pull the thread with some taughtness through the machine so it gets into the correct places under the covers so you have good tension and good stitching. Then put the bobbin back in and make sure when you thread the bobbin case that the thread "clicks" slightly as you pull the thread into the metal tension area of the black bobbin case. Anytime a sewing machine breaks thread at the needle, you should unthread the entire top and rethread it because the thread can jump out of it's guides that are under the plastic covers and you won't be able to see it, but you will see very ugly stitching!!!
Nov 19, 2009 | Husqvarna Sewing Machines
Husqvarna 2000 1974, uneven stitches
Take out the bobbin case, remove the bobbin. Using laquer thinner on a Q-tip or a thin rag, clean the center "hole" of the bobbin case. Then look at the post in the machine that the bobbin slides onto. Is there thread wrapped at the back of the post? Also clean the post with your cleaner. Once the post and the hole are clean, put a little sewing machine oil on your finger and wipe the post with it and the chattering noise of your bobbin will be gone.
Take the thread off the top of your machine, put in a new needle.
Turn your top tension to Zero and lift the presser foot, this will open the tension discs of your machine. Using a needle, scrape or clean the area between the discs. (Your needle also has a flat spot on the top of the needle, that faces the rear of your machine.) Also look for any rough edges in the hole of your presser foot or the hole in your needle plate. If there are any rough edges in the metal areas that your needle goes through, you would have poor stitching. Don't forget to put your tension dial back on the red dot before you sew.
Oct 21, 2009 | Husqvarna Sewing Machines
Needle stuck in right position, will only sew tiny,tiny stitches
Mar 26, 2009 | Husqvarna Viking 1
Sewing Machines Logo
11 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
