Question about Actron CP9550 OBD II & CAN Code Reader
CAN fail error when trying to communicate
When i hook up my scanner to my recepticle under the dashboard of my 2000 jeep cherokee classic 4.0 liter vehicle ,it goes through an LCD diagnostic ,then says comunicating , and then shows a CAN fail error...What am I doing wrong
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
You have to have the contact on, all lights on the dash must be on otherwise you get this error.
Posted on Apr 19, 2014
My headlights and dashboard lights stopped working on my 2000 grand jeep cherokee
Check the black fuse box under the hood near the battery ! Check it out on you tube !
May 13, 2014 | 2000 Jeep Grand Cherokee
Where are the spark plugs
Locate the spark plug wires in the Cherokee cylinder head. In the 4.0 liter engine, the spark plugs are below the coil rail assembly. On the 4.7 liter engine, the spark plugs are located under each corresponding engine coil.
Read more: How to Replace Spark Plugs in a Jeep Grand Cherokee ' eHow.com http://www.ehow.com/how_4484626_replace-spark-plugs-jeep-grand.html#ixzz27zi6736d
Sep 30, 2012 | 2000 Jeep Grand Cherokee
My grand cherokee 1994 engine not starting no communication with the DRB and check engine light
I assume your speaking of a automomtive scanner when you mentioned no communication. Check the fuse for you PCM, its thats good your cars computer or PCM may have failed.
Apr 18, 2010 | 1994 Jeep Grand Cherokee
Whats wrong my abs light is on, my brake light is on and my speedometer nor odometer are working? 2004 jeep grand cherokee larado 6 cyl 4.0 liter
here is the short version...
the vehicle speed sensor is actual an interpreted signal from the ABS module and the ABS module uses the wheel speed sensors
therefore, if the ABS module sees a problem with any sensor it will affect the PCM input for vehicle speed
another possibility, but worst case, is the ABS module has failed
in either case you will need a professional scan tool to monitor actual wheel speed versus PCM vehicle speed
Apr 05, 2010 | 2004 Jeep Grand Cherokee
2000 jeep grand cherokee scanner hook up
underneath the dash on the drivers side, poke your head under and look up. you will see it in that region.
Apr 02, 2010 | 1995 Jeep Grand Cherokee
2000 jeep grand cherokee 4.0 liter engine timing belt replacement
If you have the same pulley arrangement that most 4.0 engines have that pulley is an idler not a tensioner. Your power steering pump has a pivot bolt, and a slide under the pump. You adjust belt tension using the pump.
Apr 04, 2009 | 2000 Jeep Grand Cherokee
OBD II Scanner TP180-CAN Error.
if the obd 2 reader won't scan and it will not run it is probably a computer problem could even be a wiring problem to the computer not sure if you can get those checked or bite the bullet and buy one. call the jeep dealer in the morning and ask if they can check a computer to see if it is bad
Dec 29, 2008 | 2000 Jeep Grand Cherokee
Hitch installation w/electrical wiring for brake
Disconnect all that trailer connector mess and start over. Someone messed up. Do you have a 6- or 7- way RV connector, a 4- or 5-way flat (U-Haul) connector, or what? Was an electric brake box installed under the dashboard for trailer electric brakes?
Better yet, sell me your Jeep cheap, it probably can't be fixed, and it's worthless.
Jul 30, 2008 | 2000 Jeep Grand Cherokee
Actron CP9550 OBD II & CAN Code Reader Logo
91 people viewed this question
Top Actron Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Bill Boyd
Are you an Actron Measuring Tool and Sensor Expert? Answer questions, earn points and help others
