My oven randomly starts beeping over and over again!!!! Help! Nothing makes it stop...many sleepless nights because of this!!!!
YOu are most likely having a temp sensor failure, an exact model number would be needed for further diagnosis. Are you also getting an error code in the display? Pleazer Appliance...
Posted on Apr 21, 2014
SOURCE: Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
The oven temp sensor has gone bad. F1-2 would be for the lower oven and F1-1 would mean the upper oven. If you give me the model # from the sticker on the oven I can direct you to a diagram, part #, and price. These are very easy to replace. Should be located inside the oven in the upper right or left hand side. It looks like a silver rod about 4-8 inches long and crimped on the end. Most of them can be removed from inside the oven by removing the two screws, pull out the sensor (harness and all) plug in the new sensor, put the screws back in and your done. Some have to be removed from the back of the oven by removing the lower, larger back panel and follow the same process as mentioned above. Hope this helps.
Posted on Oct 19, 2007
I own the magtag gemini model MER 6770 AAW serial number 14882525YB the message I am getting from the panel is F 1-2 then it beeps until I cancel then sometimes it returns beeping. Sometimes the top oven cooks fine but if I try to cook with both ovens going it goes all crazy with beeps and shuts off and sometimes won't go over 100 degrees in both ovens. I am a very handy person and if someone can tell me how and what to replace I know I could do it. The repair center said it could be $300 plus to repair. My stove is 8 years old and I paid around $1300 for it I can't afford to replace it. HELP if it is out there otherwise I guess I will have to pay to repair it still cheaper then buying a new one...
Posted on Sep 11, 2008
SOURCE: remove probe from oven
most electric ovens have a temperature sensing probe inside of them. this is to prevent the oven from overheating and causing a fire. the reason why it's asking you to do that is because it's either dislogged from its place or it need to be replaced.
Posted on Sep 13, 2008
SOURCE: Roper electric range non stop beeping!
I'm thinking a door switch problem and/or maybe an intermittent keypad connection. Failing that, the electronic control may have failed. We repair oven controls at www.fixyourboard.com.
Posted on Sep 30, 2009
SOURCE: Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Posted on Oct 25, 2009
Jun 30, 2014 | Maytag 30" Built-In Single Electric Wall...
Aug 04, 2010 | Danby DMW753 Microwave Oven
Dec 08, 2009 | GE Ovens
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oct 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Apr 28, 2008 | GE Profile JTP56 Electric Double Oven
Feb 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Apr 23, 2018 | Viking Kitchen Ranges
