Intertherm unit wont start
    New Friend:
  • 84 Answers
Didn`t mentioned if there is an stand bye light present on front cover.anyway,if there`s no power at all,check first your crkt breaker if it was on a tripped mode,try to reset it,if it works fine,but if it still tripping off,leave it to the technicians for servicing
Posted on Apr 23, 2014
Intertherm furnace model # MMHB-070ABHR-06 red light blinks two times
Number of flashes mean different things for diff models. The meanings of those flashes should be posted somewhere on the unit; usually inside front of the bottom service panel. Though you can't truly diagnose a problem by number of flashes they can give you an idea of where to look for a problem. There are a ton of videos and how-to's about furnaces on youtube by real service techs. Most modern furnaces have basically the same set-up and features so don't worry about your paticular brand; but of course that would be the best place to start looking. You could start here to familiarize yourself with your brand of furnace:
http://www.youtube.com/results?search_query=Intertherm+Gas+Furnace+&oq=Intertherm+Gas+Furnace+&gs_l=youtube.12...62316.62316.0.63907.1.1.0.0.0.0.202.202.2-1.1.0...0.0...1ac.Ko9QBdxK6OM
And then here:
http://www.youtube.com/results?search_query=gas+furnace+won%27t+light&oq=gas+furnace+won%27t+light&gs_l=youtube-reduced.3..0.5619.10061.0.11544.11.5.0.6.6.1.741.1982.0j1j2j5-1j1.5.0...0.0...1ac.1.5-0zJyxNMEo
Hope this helps.
Dec 21, 2012 | Heating & Cooling
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
Intertherm heating unit shakes and making sounds
you either have dirt on blower wheel or it went out of balance. have had some that center hub comes loose. if its not dirt on fins wheel is bad
Feb 13, 2012 | Intertherm Heating & Cooling
Where are the filters located on the Intertherm heating and cooling unit that comes in mobile homes ?
There are a couple of places to start looking.......the first place is in the return grille. If it is not in the return grille, then the filter should be in the Intertherm unit itself.......look for an access panel marked "filter".
May 17, 2010 | Heating & Cooling
Intertherm 13 SEER split air conditioner fans wont turn on?
OUTSIDE FAN OR INSIDE FAN OR BOTH. IF BOTH CHECK THERMOSTAT WIRE HOOK UP. IF YOU INSTALLED NEW TSTAT CHECK FOR JUMPER ON RH-RC TERMINALS ON TSTAT BACK PLATE. IF INSIDE FAN COMES ON WITH FAN IN ON SETTING AT FAN ON AUTO LEVER THAN PROBLEM IS AT OUTSIDE UNIT. CHECK FUSES IN BOX ON OUTSIDE WALL. SHUT OFF BREAKER FIRST.
Apr 21, 2010 | Intertherm P3RA-060K Air Conditioner
My intertherm outside unit is clicking and I can hear a buzzer every so often. When the buzzer goes off the inside lights dim for a second. Model T5BD-048K and serial # T5A060500118. Product p3ra-048k is...
Sounds like the compressor is trying to start but is not. The lights are dimming as the unit is overamping. The buzzing noise is the motor trying to start and failing. The click is the unit going out on it 's safety device, unually an internal overload.
Hope this helps.
Feb 06, 2010 | Intertherm P3RA-048K Air Conditioner
WONT COOL OUTSIDE UNIT DOES NOT COME ON FAN BLOWS INSIDE
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
INSTRUCTION MANUAL /INTERTHERM FURNUES
usually a power surge will fry the transformer unless sometimes if your lucky the manuf. installed a fuse either in line or on the circuit board. 5 amp or 3 amp....any thing bigger wont protect your equipment.
Jan 09, 2009 | Intertherm P3RA-048K Air Conditioner
Intertherm model e3eb020h electric furnace won't start just hums
Check fuses. one may be blown, and the other one not, Therefore you are getting only 110V to a 220v circuit.
Dec 03, 2008 | Intertherm Heating & Cooling
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
