Question about eMachines 15.6" E525-901g16mi Laptop Lcd Screen
Emachines e525 says no bootable drive
Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 41 Answers
Boot to recovery mode and do a startup repair, if it doesn't help, you can either do clean install or talk to a specialist
Posted on Apr 20, 2014
This is what mine says when I turn on Intel UNDI, PXE-2 . 1 (BUILD 082) Copyright (C) 1997-2000 Intel Corporation For Atheros PCIE Ethernet Controller v1.0.0.5(01/22/09) Check cable connection..
You hard drive is missing from the system. Just does not recognize it.
Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 25, 2012 | Acer Aspire One Netbook 8.9" Notebook
Pxe-E63 : error while initializing the NIC
Check the boot sequence. For a normal boot, it should be set to hard disk as first item, not the network.
Jul 01, 2012 | Acer Computers & Internet
When start up my Emachine E525 the laptop the screen is blank, then after a while if any key is pressed a bleeping sound is made the some system language appears on the screen saying: 'For Atheros...
It seemed that the laptop is booting to the network to correct this
1. Go to the BIOS Check if the hard drive is detected by the computer (Hard drives are usually shown as alpha numeric) 2. If the hard drive is detected make sure that the hard drive is the first boot device 3. Save all changes and restart the computer 4. If the hard drive is still not detected you have to take out the hard drive and put it back in (reseat the hard drive) 5. Go to the BIOS again check if the hard drive is detected if not replace the hard drive
Hope this helps
Jun 02, 2011 | E-Machines emachines (emachinees) CD-ROM...
Acer aspire will not start. get message check cable connection! PXE-E63 error while initializing the NIC PXE-M0f Exiting Intel PXE ROM No bootable device - insert boot disk and press any key. Netbook has...
1. It seems that the hard drive is not bieng detected by the computer 2. and from the error message that you are getting it seemed like windows is not loading up 3. I would suggest that you take out the hard drive and put it back in 4. the reason for that is the hard drive that connects from the mainboard is
May 29, 2011 | Computers & Internet
I'm running a Windows 7 netbook- acer aspire one. 32 bit Prossesor- Intel Atom BOOTING ERROR- I press power and the ACER logo pops up (normal) and then: For Atheros PCIE Ethernet Controller...
This message means that the computer cannot see the hard drive. Unofrtunately, this is usually caused by a failed Hard Disk drive. However, you could try removing and re-fitting the hard drive to see if this cures the problem.
Full instructions on removing and replacing the hard drive can be found here:
http://www.laptopmag.com/advice/how-to/aspire-one-hdd.aspx
Apr 12, 2011 | Acer Aspire One PC Notebook
It says check cable connection! PXE-E63:Error while initializing the NIC PXE-MOF:Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key
This could mean a few different things:
1.) Your hard drive is bad.
2.) Your hard drive cable is bad.
3.) The cable that connects to your hard drive is loose.
If you are under warranty, I would advise you to contact the MFG. to have them replace the drive or check it out for you.
Mar 15, 2011 | Computers & Internet
When I turn on my Acer minilaptop it say: Check cable connection..! PXE-E63: Error while initializing the NIC PXE-M0F: Exiting Intel PXE ROM No bootable device--insert boot disk and press any key
Your BIOS setting or boot order was changed to enable network booting (Intel's PXE).
reboot,tap F2 to enter BIOS and navigate menu to disable network booting.
Mar 20, 2010 | Acer Aspire One PC Notebook
My computer fell and when I turned it back on it's saying check cable connection..! PXE-E63: Error while initializing the NIC pxe-m0f:Exiting Intel pxe rom no bootable device
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Nov 09, 2009 | Acer Aspire One PC Notebook
eMachines 15.6" E525-901g16mi Laptop Lcd Screen Logo
122 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
