SOURCE: Washing Machine Will Not Drain
you have got a blocked filter or pump the filter is located on the right hand side at the front of the machine down the bottom behind the plinth you can drain the water from there as well by pulling the small grey hose out pull the plug out of the end and place in a small bowl good luck when the water is out you can check the pump impeler as well clean the filter houseing and put it back all should b well unplug the machine b4 u start work
SOURCE: bosch exxcel wf02465 wont spin
We had similar problem, with the spin cycle not working. We opened the 'drain' pipe (front-right bottom side). It was full of lime scale; never been opened for years. We cleaned it up and the spin cycle is now working.
SOURCE: f04 error message on a bosch exxcel 1400 washing
This error indicates an obstruction in the water pump. . Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
SOURCE: I don't have a User Manual for our Bosch Exxcel 7
I think you press and hold for ten secs to clear its a childlock
SOURCE: bosch exxcel 1200 express washing
I had F63 on Bosch washing machine (Maxx 7).
I waited 5 days for a repairman and all he did was reset the washing machine processor, like this:
1. Turn the program knob to 6 o'clock
2. Hold the RPM button
3. While the RPM button is held, turn the program knob 1 click clockwise (to Rinse)
4. Release the RPM button.
This is similar to F21 which also happened to my machine.
Apparently both errors are related to power surge/power cut.
