Question about Sub-Zero 561 / F
Sub zero freezer freezing up on outside back panel line causing rust and melting
  • 884 Answers
Is it on the copper tubing coming out the back? Insulate the pipework with foam insulation. If it's on the back of the freezer. the wall insulation has blown (not repairable)
Posted on Apr 22, 2014
JOE LLAMA
  • 26 Answers
SOURCE: Sub Zero Freezer Vacuum
If your freezer temps are ok, it may just be that your gasket is getting older and it becomes more porus as it ages. The vacume sound doesnt really mean alot except that the difference in the room temp and the cold of the freezer create this vacume.
Posted on Mar 31, 2008
  • 7 Answers
SOURCE: ICE MAKER SUB ZERO REFIGERATOR
Check water turned on. check ice button switch turned on in fridge. remove juice storage, ice container in freezer, check ice bucket full white plastic flapper to make sure not stuck on a white peg at top. flapper must hang down and be freely movable to signal ice maker to keep busy. If up high will turn off ice maker. Lots of other parts especially heater circuits involved also: fill tube supply heater not working then frozen supply line then no ice. Look for wiring diagram in ziplock behind compressor grille. can order parts at repairclinic.com. logical design, layout, easy to get to sensors, heaters. makes sense if look at it long enough.
Posted on Jun 01, 2008
SOURCE: Sub-Zero 550 water dripping on right side of freezer forming ice on draw
I had a similar issue that started about a year ago with my Sub-Zero 550. My freezer gasket actually tore after several times of freezing closed. I thought that a new gasket would solve it, but a second but related problem developed where I was getting alot of condensation under the left side of the unit, with the water dripping onto the floor...eventually staining the hardwood floor in front of the unit.
I traced the problem to a clogged condensation drain pipe in the refrigerator. It is a corrugated pipe that drains a trough behind the crisper drawers. My pipe was clogged with black sludge and frozen down below. The condensation in the fridge would overflow out of the trough and leak below the crisper drawers, down out through the gasket.
To resolve, I used a piece of solid thin wire folded in half and twisted with a small loop at the end to fish out as much sludge as I could. Then squirted hot water into the pipe until it totally unclogged. I believe this will solve the problem without any need for a heater underneath the unit. The 550 worked fine for 4-5 years before this happened.
Posted on Nov 29, 2008
  • 56 Answers
The drain line has been clogged. There is actually a defrost heater kit for that problem if you can get the obstruction out. Did you call factory at 800-222-7820 or a local factory authorized servicer? The drain is accessed by removing the fan shroud and evaporator cover. There are a number of of phillips head screws that hold this in place. Once you have removed the two cover you will see the drain tube on the left side of the unit. I use a hair dryer to start defrosting the tube. If you have another freezer in the house it is easier just to turn the freeezer section off for a day or so. I use nitrogen to blow the line out from the bottom once everything has defrosted. Test for water flow, then put unit back together. Call the factory at the number above for the heater kit part number and they will also give you the local authorized parts supplier. The locator web address is http://subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code
Posted on Feb 22, 2009
wheelshot
  • 102 Answers
SOURCE: sub zero refrig - ice forming inside
The solution posted previously is TOTALLY WRONG. A Sub Zero ref doesn't have a heating element in the fresh food section. Only in the Frozen food section. It has 2 totally separate systems for each section. 2 Compressors and 2 evaporators. They share a condenser. If you are having ice build up in the refrigerator then the problem you are having is a refrigerant leak in the fresh food evaporator. You need to have a certified tech come out and replace the evaporator in your refrigerator section of your Sub Zero. Not sure what you are asking about the thermostat.
Posted on Apr 11, 2009
Sub zero 501 freezer and refrigerator ice builds up on back panel
Possibly the timer that controls the defrost cycle is defective.
Do you get any defrost melt water in the pan below the frig?
Sep 01, 2012 | Sub-Zero Refrigerators
We have a 5 year old side by side sub zero fridge/freezer (largest size)
check whether the temprature is set properly in the freezer on proper level.
Sep 27, 2008 | Sub-Zero 685/S Stainless Steel Side by...
Our Subzero 611 (fridge above, freezer below) is leaking water behind the unit. We pulled the unit out of the wall and discovered that the center panel on the back of the unit had a big rusted spot. We...
That is the suction line which carries refrigerant (freon) and indicates a sealed system problem which must be attended to by an EPA "Certified" Technician.
Jul 04, 2011 | Sub-Zero 611 / O Bottom Freezer...
Freezer not working but refridgerator section ok. this is a sub zero unit
It is a defrost problem since the ice that freezes on the freezer coils
is not being melted by the defrost system.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
 Its best handled by a Technician butyou could possibly do it by taking your model number to the nearest appliance parts store  and asking for the parts.  They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref  The parts store will have info  Also check evaporator fan in freezer If this was helpful please rate me
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net"
Sep 05, 2010 | Sub-Zero Bottom Freezer Refrigerator
My Sub-Zero drain ices up too!
There is a drain tube heater and a floor pan heater kit for this model from Subzero
This is Not for a DIY project
Affordable Appliance Repair
Lake Forest, CA.92630
Aug 21, 2009 | Sub-Zero Bottom Freezer Refrigerator
Drain in fridge is clogged - ice formation under crisper drawers
We have cleared / de-frosted the drain twice and it keeps freezing up, causing the accumulated ice problem to recur. Should the freezer settings be changed?
Aug 13, 2009 | Sub-Zero Bottom Freezer Refrigerator
I have a Sub Zero 201 F, that ices up around the freon line.
It sounds like your fridge has had some servicing done on it and has been over charged with freon and needs to be decanterred.Kind Regards.
Jul 09, 2009 | Sub-Zero 650 / O Bottom Freezer...
550 Sub zero
your drain is clogged or frozen over,the drain is most all the time in the middle back bottom of freezer,you might have to remove the freezer back wall to get at the drain,use a hair dryer to melt the ice and a metal hanger to clear the drain,let me know how you make out-mike
Nov 02, 2008 | Sub-Zero Refrigerators
Water "pouring" from freezer condenser
sounds like drain in freezer is clogged and has iced over
so when unit goes into defrost water leaks into freezer bottom and freezes
you can either shut off fridge for a day and let ice in drain melt
and hopefully clear line
or u can take back cover off freezer section pour hot water in drain pan and make sure drain hole is cleared and draining down to pan
Jun 21, 2008 | Sub-Zero 611 / O Bottom Freezer...
Refrigerators Logo
124 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
