Question about ESA ET427E 27" TV
AV channel I am trying to hook up my DVD player but I cannot find the actual input channels... help!
  • 26 Answers
Hi There. If you're connected to either AV input. (mostly RCA yellow, black and white receptacles), to by Scart, you must be able to switch your TV set to "External". There can be one or more "externals". F.i.
the ones described here: then you must be able to choose External 1 or External 2. There must be a button for this on your remote control.
Sometimes however, it goes by an menu. Choose Setup, or menu in general. There you'll find the way to select which input you want to use. So select the right one, then exit by the OK button.
Posted on Apr 30, 2014
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
I need to connect my Panasonic DMR-E85H DVD to an old HMV TV. I need to know what the frequency of the out pout would be for the A1, A2, A3 output channels from the DVD and what the input frequencies...
It doesn't use TV channels, it uses AV, Audio Visual, input. That means you hook up, to the, whats called the EXTERNAL Inputs, A1, A2, A3, these are the external inputs that relate to the Jacks on the rear/side of the unit. You use the output from the DVD, and hook it up to the AV input on TV. Press Play on DVD and Select, correct external input on TV. Usually it;s Yellow to Yellow Red to Red and White to White.
Mar 02, 2010 | Panasonic DMR-E85H DVD Recorder
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Have no remote trying to hook my dvd player to tv cant get it to find av or aux channel on my broksonic ctgv 4563tct
Try the channel buttons and go below channel 2 or above 125 that`s usually where you will find the video input. Hope this will help.
Dec 01, 2009 | Broksonic CTGV-5463TCT TV
I can't find the dvd input for my hitachi tv
DVD has AV out pins at rear, hook AV cable between DVD player out and TV AV input (yellow-red-white RCA pins) and select that AV input in TV by remote that you hooked DVD.
That will switch TV to that input and TV will show you DVD player picture.
Sep 20, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Can't get dvd player to work on this tv!!!
im guessing that you cant go to av mode because you dont have a remote, am I right? if thats the case you need to go to walmart and buy an RF converter. You can plug you dvd into the converter, then run a coax cable from the converter to your tv coax inout aka anteanna input, then depending on your converter switch your tv to either channel 3 or 4 and presto. it will hook up just like vcr's and onld nintendos use to. You can pick up an RF converter cheap at walmart or check e-bay, couple bucks and your watching dvds.
Jun 23, 2009 | RCA F36649 36" TV
Problems hooking it to the television
The colored jacks match up to the jacks on tv. Tv must be turned to AV channel, Or input channel. The ports they are plugged into should have a channel printed by them.
If you are hooking it up through a VCR it is the same. Whatever it is hooked up to has to be on the right channel.
Channels are usually: AV or Input
Jan 18, 2009 | GoVideo DV2140 DVD Player/VCR
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
Hook up
You can by an AV splitter box from dick smith or even k-mart audio section that allows you to plug all your units into it, then leads go to your TV. There is a switch on the box which you flick over depending whether you want to watch a DVD or play your game unit.
The other option is to have a llok at the back of your DVD player. Some have input AV's (the red, white and yellow holes !) where you could plug your game console into. Then you just leave your dvd plugged into your tv as normal. To play your game console you turn on TV and DVD player. Have TV on "AV" channel as well as your DVD player on "AV" channel (may also be your input or component channel.
Hope this helps :)
Feb 24, 2008 | Televison & Video
ESA ET427E 27" TV Logo
60 people viewed this question
Top ESA Televison & Video Experts
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
