Question about LG L204WT Television
I have a flashing blue light on the screen
I have a flashing blue light. I unplugged the screen and the problem returned. No screen view.
  • 286 Answers
This is a generic symptom that could happen to any LCD monitor.
The following is a generic answer applicable to most.
First check to make sure you're not over range. Unplug the monitor from your computer and turn it on. If you get any kind of a picture, and the light stays on for a while before shutting off or starting to blink, or if the display says "no signal" then there is likely nothing wrong with your monitor. Plug it back into your computer and try starting windows in safe mode. (tap F8 repeatedly until you get a boot menu and select safe mode). Right click on the desktop, select the rightmost tab and reduce the resolution using the slide bar. Reboot your computer and everything should be fine.
If you cannot get any display at all, then try this:
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that runs the lights. Sometimes these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
If you cannot do that or don't want to take it apart, bring it to a service centre for an estimate.
Posted on Jun 19, 2009
There is a blue light flashing on rear view mirror. Why?
Usually a flashing blue light is from an aftermarket installed alarm system or remote starter.
You may want to check your owners manual if the light is in the mirror glass.
Feb 21, 2015 | 2009 Hyundai Accent
How to get my new Bluetooth set-up
So, what else can I tell you. You yourself have discribed that your headset is defective. So, being a new device, return it to be changed for a new one.
Jun 03, 2014 | Apple Cell Phones
16" lcd new out of box flashing blue light on power indicator
Under a year old tv?This tv have power supply problems.Call the for warrenty repair.Or tries websites like shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 14, 2010 | LG 32LG30 32 in. LCD HDTV
The screen was unplugged and now when plugged in the blue light around the power buton just flashes
I tried the reset procedure, i've left it unplugged now for a week and upon ... Now the fifth died. This time, no illumination, just flashing blue light. ... The screen is completely black, the power button is dark blue and no amount of ... The monitor was gone for about 2 weeks (maybe 3) I left it plugged in and ...
deliverator.silverfir.net/?p=369
Dec 04, 2009 | Samsung SyncMaster 932B LCD Monitor
View sonicvx2235wn
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
If you can hear audio then your problem should be in the inverter board.
It could have bad capacitors or possibly a burned out transistor.
There is a chance one of your bulbs is creating a problem, but you would usually see a flash of the screen if that were the case.
Even though you do have sound the power board could still be the culprit.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
Should the screen happen to light up all white, then your inverter is okay.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
ebaysbammbammfran
Oct 12, 2008 | ViewSonic VX2235wm LCD Monitor
Monitor is black and blue light flashing
Boot from safe mode and try a different pixel/color arrangement. Obviously a lower pixel and color setting.
Mar 25, 2008 | Computers & Internet
Apex gb4308 flashing blue screen and cycling channels
Sounds like a power supply problem to me. Could be caused by the actual supply, or could be a component failure elswhere...accordianman
Nov 04, 2006 | Apex Digital GB4308 43" Rear Projection...
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
LG L204WT Television Logo
138 people viewed this question
