Question about DISH Network Televison & Video
Changing channeols I can not get the remote to change channels, please help me with this.
    Top Expert:
  • DISH Network Master
  • 75,404 Answers
Check the TV settings. If it is set to AV, no channel selection will be available. If select the input to TV, and check.
Posted on Apr 19, 2014
4 Suggested Answers
SOURCE: please help
It depends on brand. For Philips, press mute button to save code. The best website I found for all brands of remote codes and instructions is http://www.remotecodelist.com/remotes/
Posted on May 15, 2008
cammykins
  • 149 Answers
SOURCE: RCR311W Rmote will not change tv channels
It appears you need to program the satellite device code back into the remote. Has this worked for you before or just started this trouble out of the blue?
You can some times have the satellite providers install the remote or insert the code information for you [for free most of the time] otherwise you can contact the satellite provider directly for the discrete coding based upon your remote control.
Keep us informed on how things go for you. Thanks!
Posted on Jun 16, 2008
BeckiB_DISH
  • 286 Answers
SOURCE: we have two tvs connected to 1 main thing...2
Hey there! My name is Becki Barned, and I am with Dish Network customer service. What you have going on here, if it has not already been resolved, is that the remotes are interfering with each other, or you are getting interference with a nearby remote, such as a neighbor's remote. Here are some simple steps to reprogram your remote! http://www.dishnetwork.com/SupportSection/remote-control and also, make sure that your main receiver box is in dual mode (it should have 3 lights- yellow/green/blue.) Hope this helps! Happy troubleshooting!!!!
Posted on Dec 25, 2010
My viewsonic keeps changing channels which makes it impossible to use. We've unplugged it and everything. once you power it on, thats all it does. it continueusly changes channels. please help
The first thing to try is to see if a button is stuck on the remote or on the TV.
Remove the batteries on the remote and see if that helps. If it fixes the problem, you'll need to replace the remote.
If that doesn't help, look close at the buttons on the TV to see if one is jammed on. If changing channels continually up, then check the channel up button on the TV, if down then check the down button.
Worst case, you might have to take the back off the TV and unplug the cable feeding the external button panel on the TV and only use the Remote (for safety, rememeber to unplug the TV while doing any work on it).
Nov 28, 2013 | ViewSonic N3235w 32" LCD TV
Need to change tv to channel 3 without remote!
go to menu and see if you have channel selection on go down thaT way. you should be able to program it in.
Feb 16, 2010 | Televison & Video
Remote stuck--can't change channel or turn off TV
Pull out the power plug of your TV and don't use it for few minutes. Remove batteries from your remote and keep it without batteries for few minutes. After about 15 minutes your TV and remove both will work fine.
Jun 15, 2009 | Logitech Webcam
My remote is driving me CRAZY!!!!!!!
1) Manually turn on the device to be controlled.
2) Press and hold CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3) Press and quickly release the desired mode button (TV, VCR etc.) . The red indicator blinks off once.
4) Press the CHANNEL UP button repeatedly ( up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction forward again.
5)Press and release MUTE to install the code.
Hope it helps~
Oct 27, 2008 | Philips PM435S Remote Control
Please help
Apr 25, 2008 | Philips Magnavox Learning Universal Remote
RCA rcr311w remote won't change tv channel to Video 1 or Video 2 channel
my universal unit won't change the tv channels, everything else works except the channel changing. Does anyone have a solution., The company is only open during the week.
Feb 08, 2008 | RCA RCR311B Remote Control
Problem with channel changing
You must program the tv. Go into the MENU and find AUTO PROGRAM. Then program it and it should work.
Sep 11, 2007 | Sharp 27K-S100 TV
Tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Jun 23, 2006 | Sylvania 6427TE 27" TV
Televison & Video Logo
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
