Question about Magic Chef 9122 Gas Single Oven
Don't know where to light it
Where do you light it?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Check owners manual, or download owners manual, it is important to know lighting instructions.
Posted on Apr 19, 2014
Testimonial: "I said Chef Norfolk infra ray gas wall oven & grill model 075GM2 how to light this one please?"
Oven temperature on Neff 195305317 circotherm oven
hi remember that electric can kill you even if it is unplugged, if you don't know what components are likely to hold charge or have large inductance get someone else to fix it.
you need to get the service manual as tis will have fault finding charts, part numbers, location of sensors etc. If you can't get manual then:
Not likely to be temp limiter as this cuts out if temp is too hot. Find temp probe, may be ntc, mercury vapour switch etc. take probe out disconnect leads and measure resistance, heat, or cool, probe measure resistance if not significantly different (ie 10k to 100k or 100k to 300k) then probe is shot. Take probe to spares place, get replacement and refit. Be very careful to refit leads exactly as they came out, don't want insulation to melt and oven to become live. test with oven or meat thermometer as new sensor may need calibration. Should be accurate to within 10C or so
hope this helps
Nov 10, 2012 | Neff Ovens
Need wiring diagram for SMW272.
Hi I have the manual for it , I don't think it has the wire diagram , may i asked why you need it ? and i will do some diging for you , but it dosent look good ,i will need a email address to send you the one i have I don't know how attached it here !
Frank
Dec 14, 2011 | Ovens
How to get light cover off inside oven
Hi Not knowing the type of oven , I can only think it must be a screw type, try turning it to the left of course don't turn it too hard in case it comes out some other way , when yo replace the bulb wipe it off with a clean towel to remove your finger marks on the bulb it will last twice as long by doing this
Dec 07, 2011 | Ovens
Electrolux E@30GS65GSD bottom oven won't heat
most likely it is a bad element easy and cheep to replace check element for burn spots on it with a flash light don't touch unless you have the power turned off , get back to me if you need a part but i will need all info on this oven
Dec 06, 2011 | Electrolux Ovens
Microwave snot statrting
Hi it sounds like a bad door switch, cause they are so dangerous ,it won't let it run cause it thinks the door is open . they have safty door switches , If you don't know much about electricity don't go inside a microwave
Dec 05, 2011 | KitchenAid Architect® KEMS308SSS Stainless...
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
I need to change the light in Bosch Oven HBN3260 GB but I can't the light casing off. Any ideas. I have lost the manual
Wriggle it from side to side and up and down while trying to twist it or the other trick to use is to grab it gently with a pair of grips with some kitchen roll wrapped around it so you don't damage the glass...... This is usually the way it comes off.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Bosch Ovens
Hi, I have a wo570xd double oven and the controller is playing up, ihave had F& P send me a new controller (572942p), this controller did not work so contacted them again and they have sent out a new...
fisher & paykel oven model WO570XD seems to be no power from source to the wall oven however range top works fine. Power light on switch to oven is illuminated indicating there is power however there is no lighting on digital display unit. Any help appreciated
May 31, 2011 | Fisher and Paykel Ovens
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Jenn air 2001 double oven , light display is out...
it would be nice to figures this out but i have not. the light unit or the power supply unit is bad but i don know which. both units cost about $150 each. so you want to be sure when yoou order your part which is bad
Nov 07, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Magic Chef 9122 Gas Single Oven Logo
35 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
