Question about Garden
Need a part for Homelite model HP3127S pressure washer - 3100 PSI
I broke the brass fitting which threads into the top of the pump. You strip the plastic see through hose which is used to suction soap from the soap container onto this nipple/fitting. I threaded a bolt into the hole intending to bypass this hole which blows water under force if you try to use the unit without fitting. No luck because it seems that this fitting allows an appropriate amount of air intake neccessary for operation of pump. I did get an operators manual with this Home Depot purchase but unlike many other ''tools'' I got no exploded parts view which would allow me to isolate and order. I like this pressure washer but I'm having no success in finding a local dealer that can help me.
I lucked out when I managed to locate a local rent it centre who sells and services Homelite equipment. I bought my pressure washer at Home Depot and when I approached staff there regarding my problem, they had no idea if there even was a local dealer who sold/serviced Homelite stuff. telephone enquiries finally led to the rental place who ordered the part for me. I was getting concerned!
Posted on Jun 20, 2009
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Excell pressure washer
What is your model #
http://www.ppe-pressure-washer-parts.com/excell-devilbiss-pressure-washer-replacement-pump-parts
Nov 03, 2013 | Homelite For Excell - Pressure Washer Pump...
Cannot find fuel shutoff valve
Some units does not have a fuel shutoff valve.
Sep 27, 2013 | Homelite 308653009 Blackmax Husky Pressure...
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Can't get pressure from homelite hp3127s gas pressure washer after using only 1 season. can't find manual to find problem. is there a switch i'm missing?
No,it's probably a bad valve body or the pump itself broke. Homelite isn't the best quality machine.
Jul 14, 2009 | Garden
I did not receive a users manual with my Homelite HP3127S
Hi, I contacted Home Depot in regards to a manual for your pressure washer and was told that it was the stores responsibility to provide you with the manuals for your product. I also visited the Homelite site and there is no literature available as a part. You must register on their website to send an email with your request if you choose that option. I also had your experience in trying to locate a manual online. I believe your best recourse is to contact the manager of the store where you purchased the unit and explain that you need a manual and were advised by Home Depot customer service to attempt to resolve the issue with the store first. Let me know if you need further assistance. Hope this Fixsya!
Mar 09, 2009 | Garden
Garden Logo
1,146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
