Question about Vehicle Parts & Accessories
How to lift rear backseat nissian lucino
Child was sick in car, ***** ran down and under the back seat cushion. Can this be removed/ lifted to clean underneath?
    Problem Solver:
  • 8 Answers
You should be able to locate the bolting system below the set, should unbolt, push back and lift up
Posted on May 11, 2014
2 Suggested Answers
SOURCE: Kids are sick
There are many products you can use to clean up. The best way is to use a hand held carpet shampooer or they have vehicle ones at a lot of car washes and just clean it like any other carpet.
Posted on May 02, 2013
How to remove backseat of a pontiac g6
backseats usually come out by lifting the back rest section first. It takes some muscle to get hands under the cushion and lift it from its mounts. The seat section should also lift from the front of the cushion and release from the mounts too. Sometimes it takes a bit of manipulating to find that sweet spot of removal of these sections.
Jun 22, 2015 | Pontiac Cars & Trucks
How do you remove the back seat to get to the fuel pump?
On what? 3 possible ways the rear seat cushion is removed. On some the seat has clips that lift straight up. Or some have 2 small bolts at front bottom of rear cushion. Remove the bolts and seat slides out easily. The final way is old style: a heavy wire on bottom of cushion, one on each side, fits into slots that come up from the frame underneath. To remove, push cushion hard to the rear until the heavy wires can be removed (lifted up) from the slots. Do one side at a time. These are the most difficult to remove the rear bottom cushion. You have to push hard against the cushion near the bottom of it, pushing it backwards, so the wire comes out of the slot, and then cushion can be removed.
First try lifting straight up on the cushion. Since there is an access panel to the gas tank, it is very possible the cushion is easily removed by lifting straight up.
Jun 05, 2015 | Seat Cars & Trucks
I want to remove the lower portion of the backseat (the cushion you sit on.) How do I do that? It is an Impala 2005.
most back seat cushions just push in and pull them up. there on clips. Push bottom cushion towards back of car, lift up. good-day !!
Jul 10, 2011 | Chevrolet Impala Cars & Trucks
How to remove bottom of back seat need to remove seat to remove rear shocks..
PUSH IN CENTER FRONT EDGE CUSHION TO DISENGAGE PART OF SEATS WIRE FRAME FROM CLIPS.WITH CLIPS UNHOOKED LIFT UP AND REMOVE SEAT.IF REAR SEAT NOT HELD IN PLACE WITH CLIPS. LIFT UP THE REAR SEAT CUSHION AND PIVOT IT FORWARD. DETACH THE RETAINING BOLTS AT THE LOWER EDGE OF THE SEAT BACK AND IF NECESSARY REMOVE THE SEAT BELT ANCHOR BOLTS.LIFT UP ON SEAT BACK REMOVE IT..
Feb 06, 2011 | Jaguar X-Type Cars & Trucks
Truck lock is jammed by briefcase strap. can i get into the trunk from the back seat? such as does the back seat fold down?
I searched the owner's manual and there was no mention of folding the rear seats down. If you don't have a manual, you can get one here: http://www.extendedgmwarranty.com/owners-manual/buick/1999-Buick-Century.pdf
You can remove the seats following the instructions below from autozone.com.
Rear Seats
SEAT CUSHION
Fig. Typical W-Body rear seat cushion removal
  1. Locate and remove the small bolts at the front lower edge of the seat cushion.
  2. Pull the tabs on the rear cushion retainers.
  3. Remove the seat cushion by lifting up and pulling out of the retainer.
  4. Installation is the reverse of the removal procedure. Make sure the retainer tabs are snapped into place. Tighten the bolts to 18 ft. lbs. (25 Nm).
SEAT BACK
Fig. Typical W-Body rear seat back removal
  1. Remove the seat cushion as described above.
  2. Remove the anchor nuts securing the rear seat retainer at the bottom of the seat back.
  3. Grasp the bottom of the seat back and swing upward to disengage the offsets on the upper frame bar from the hangers.
  4. Lift the seat back upwards to remove from the vehicle.
  5. Installation is the reverse of the removal process. Make sure the hooks on the seat back are properly installed to the hangers. Tighten the anchor nuts to 89 inch lbs. (10 Nm).
Nov 07, 2010 | 1999 Buick Century
How do i remove the backseat in my thunderbird?
Rear Bench
(see Figure 4)
  1. Bearing down with your knee on the rear seat cushion, push the cushion rearward and disengage it from the retaining brackets.
  2. Remove the rear seat armrests if applicable.
Fig. 4: Pull the bottom of the seat upwards and pull out
  1. Remove the seatback lower retaining screws and seat belt bolts.
  2. Grasp the seatback at the bottom and lift it up to disengage the hanger wire from the retainer brackets.
To install:
  1. Position the seat back assembly so that the hanger wire is fully engaged in the package tray slots.
  2. Install the lower retaining screws and tighten to 13-19 ft. lbs. (17-37 Nm).
  3. Position the seat cushion assembly into the vehicle.
  4. Apply knee pressure to the lower portion of the seat cushion assembly. Push rearwards and down to lock the seat cushion into the seat retainer.
  5. Check the seat cushion to ensure it is secured into the floor retainer.
Rear, Fold-Down Seats
  1. Push the rear cushion rearwards, then lift to release. Remove the cushion.
  2. Remove the 2 lower retaining screws attaching the seat back to the floor.
  3. Lift up and disengage the upper clips of the seatback from the top of the folding floor.
  4. Remove the seat assembly.
To install:
  1. Position the seat back assembly and align the retaining hooks. Ensure hooks fully engage in slots.
  2. Install the two outboard retaining bolts, then tighten to 13-19 ft. lbs. (17-27 Nm).
  3. Lower the seat backs and install the upper retaining screws.
  4. Install the lower center retaining screw, tighten to 13-19 ft. lbs. (17-27 Nm).
  5. Install the rear seat cushion. Ensure the rear seat cushion front retainers latch properly.
Hope helps (remember rated this).
Jul 01, 2010 | 1994 Ford Thunderbird
Remove backseat of honda accord 1991
With your hands, press down on the seat cushion where it meets the seat back. Locate the retaining bolt(s). Some models retain the seat with one bolt in the center; others use two, evenly spaced left and right.
Remove the retaining bolt(s).
Life the back (toward the rear of the car) of the seat bottom upwards while rotating it toward the front of the car.
Disconnect the hooks at the front edge (during the rolling motion) of the seat and remove the seat bottom.
Remove the carpet (in the luggage compartment) from the rear of the seat backs.
Remove the seat back mounting bolts from the luggage compartment side.
Lift out the seat back.
If the rear side bolsters or pads are to be removed, remove the lower mounting bolt, then push upward to free the hooks.
Hope this helps you.
Oct 17, 2009 | 1991 Honda Accord
How to remove seat cushion for repair
Since you mention two front seats, I assume you have bucket seats. These are pretty easy to remove, just look under the seats for the 4 bolts that go into the floor. You may have to feel under the floor for the bottom end of each bolt to get a wrench on it.
The rear seat is a bit more tricky. Remove the bottom cushion first, by pushing down HARD on the front edge of the seat (SIT on it!), and then, while pushing the front edge down, also push back on the front edge of the cushion - it will move back about an inch, and that will release the hold down hook that holds it in place. Then you can just lift out the seat cushion.
The rear seat backrest has two bolts that you can get at after you remove the seat cushion - they go into the floor under the bottom edge of the rear seat backrest. Take those two bolts all the way out, and then grab the rear seat backrest, push it back toward the trunk while you lift up on the bottom edge. Don't pull it away from the metal backing, just slide it up toward the rear window - that will release it from the holding hooks at the top of the rear seat cushion and the whole cushion can be lifted out of the car.
If your car has a center console in front, or a speaker grille in the middle of the rear seat, you will probably have to look around for the mounting hardware - the console is bolted to the floor, and you will probably have to take it apart or remove the shift knob to get it out. The rear seat speaker grille, if it is between the two sides of the rear seat backrest will be bolted to the metal braces behind the rear seat. You may have to climb in through the trunk to get at those.
Just a word of caution regarding Mustangs: The floors are an important structural part of the car, since it has no frame - if the floors are rusted, the car may very well be unsafe to drive - I advise you to have it inspected at a frame shop to see if it is able to be made safe to drive before you spend a bunch of money on a losing project.
Aug 22, 2009 | Baby Gear
How to remove rear seat from 2001 Audi allroad
Not 100% sure on yours but normally you'll either have a couple of bolts way down under seat cushion at front, near floor, or in some cases, you have to push seat cushion back toward rear window, hard & lift, to pop it out of notched catch under it.
Mar 14, 2009 | 2001 Audi allroad
I want to make my 1999 Mercury Villager Sport into a cargo loader, with just the front seats kept and the rest of the back empty. How do I remove the other 3 seats? So far, I can't get any of them to budge...
the middle seats come out easily. There are 2 handles you have to lift up on each of the bucket seats, they are in the front of the seat down by the seat tracks. After you lift them, tilt the seat upward in the front and rotate them backward. Then lift out of the hooks. Each seat is held down by 4 hoks.
The 3rd row seat is not designed to come out xcept by a technician. It does slide forward all the way up to the front seat. It has a sliding seat track.
First, lift the T handle under the seat cushion on the left front side of the seat. This will allow you to lift the seat bottom up all the way to lcok in the full up position.
Then, lift the lever on the same side of the seat and slide the seat forward. It will stop in 4 places.
Rear -Rear
6 inches forward of that.
another two ft to the second row seating position
full frward against the front seats.
Pleae rate as fixya if this helps.
c4253aa.gif Seat —Third Row Bench Removal
sxv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Removal of the third row bench seat requires more than one technician.
  1. Remove the second row seats. For additional information, refer to Seat—Second Row .
  1. Remove the floor mats.
  1. Lock the seat cushion in the upright position.
    1. Lift the handle to release the cushion.
  1. Move the third row bench seat to the second row position.
    • Lift the seat track release handle.
  1. Remove the two bolt covers.
  1. Remove the two seat track front bolts.
  1. Remove the four seat track rear bolts.
    1. Position the rear seat cushion floor cover aside.
  1. Remove the third row bench seat.
Mar 02, 2009 | 1997 Mercury Villager
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
