Question about Kitchen Ranges
Kitchenaid model YKGSC308LSO is showing code PF
I unplugged it and plugged it back in. Control panel shows "control lock", that goes out in about 10 seconds and shows code "PF". Touch screen is non-responsive.
  • Terry Huston
    Terry Huston Apr 20, 2014
    This is a pic of our touchscreen. It's unresponsive. I have unplugged for 5 mins then plugged back in. The screen shows "control lock" for about 10 seconds, then goes back to PF, still unresponsive:(
    Top Expert:
  • Kitchen Ranges Master
  • 9,472 Answers
Press and hold the Start pad for 5 seconds until "Control Lock" appears on the display. Repeat to unlock, and "Control Lock" will disappear from the display.
Posted on May 01, 2014
Frigidaire microwave key shows a lock and no keys work
Here is a previous answer that might be of help.......
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it is still locked or goes into lock mode by itself, the "clear" key on your keypad may be shorting.
Here's how the child lock works on model FMV145:
Child Lock-Out
You may lock the control panel to prevent
the microwave from being accidentally
started or used by children.
To lock or unlock the controls, press and
hold CLEAR/OFF for about three
seconds. When the control panel is
locked, an "L" will be displayed to the
extreme right.
Jun 07, 2016 | Frigidaire Microwave Ovens
Touch pads on my kitchenaid electric range do not work, no error appears
Do the buttons beep when pressed if so bad control do know the model number the keypad and control might all be in one the PF is normal indicated Power Failure
Dec 31, 2014 | KitchenAid Kitchen Ranges
What is wrong if my Frigidaire front load dryer
Thank you for your inquiry, friend!
I understand that your Frigidaire dryer has been providing you with an error code "PF". Typically "PF" stands for power failure this can happen if power is shut off during a cycle or the dryer receives insufficient power, which could be an issue with your power cord or control panel. Let's perform a reset on your dryer and you can do this by unplugging the power cord for ten minutes. If you need any additional assistance please feel free to reconnect. -Matt
Oct 14, 2014 | Dryers
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
Sears dryer model 417.84092500. It turns on for about one second, stops, then it shows error message PF. How do i fix it?
Hello & Welcome to FixYa
PF error means power failure which is generally caused when the control board inside the unit goes bad. You can try unplugging the unit for 15-30 minutes, if the issue returns then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | Kenmore Dryers
KitchenAid built in microwave model #KHMS155LSS-4. My microwave keeps beeping and I am also unable to unlock the keys. What I tried to do already is unplug the unit and plug it in again. No change. Then I...
Whirlpool is conducting a safety recall on the Kitchenaid KHMS155L series (and similar models under other brand names) that display the F2 code or have been observed self-starting. Other symptoms may be additional codes or unintelligible info being displayed, and failure to execute the command entered into the control pad. To obtain free replacement of the control panel, call Ava at Whirlpool: 1-866-640-7146, extension 6337. She will want your complete model and serial numbers and a phone number and address where you can be reached. She will arrange for A & E Factory Service to contact you to set up an appointment to come out and replace the control panel at no cost to you.
Jul 06, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid gas range model# ykgsc308lso oven
If it takes more than 2 minutes to light then that ignitor is weak. It should be very bright. It has to draw 3.5 amps to open the valve. The valve is good because the ignitor is working the oven control is good, all it can be is a weak ignitor. It should draw 3.5 amps or have measure 37 ohms.
Jan 14, 2010 | Ovens
Microwave bleeps and display shows F3
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
Feel free to contact us with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
Jul 13, 2008 | Whirlpool GS460 Gas Kitchen Range
Kitchen Ranges Logo
277 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
