Question about HP OfficeJet t45 All-In-One InkJet Printer
Receiving a "Insert color cartridge" error message
I replaced the color and black cartridges of my HP T-45 printer and get an "Insert color cartridge" error message. I have tried removing and replacing both cartridges, and cleaning the contacts with distilled water, as recommended by the Troubleshooting section of the OfficeJet Manager. What can I do?
  • ttwedt Jun 20, 2009
    No, the old cartridge does not produce the message. Wonder if that means the problem is the new cartridge?
  • Joe Fine May 11, 2010
    When you try to reinsert the old cartridges, do you get the same message?
  • 628 Answers
You hit it! Go out and buy a new cartridge. Most likely you got a bad one.
Posted on Jun 20, 2009
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Cartridge error refer device documentation troubleshoot
Remove the black cartridge and keep only the color cartridge in, and check the message. Now remove teh color cartridge and insert only the black cartridge in, and check the message. This should give an idea about which cartridge has a problem.
Feb 17, 2011 | HP Officejet 5610 All-In-One InkJet...
HP 4215 "cartridge Error"
Remove the color cartridge and close the lid
If the error comes up again, remove the black cartridge and insert the color cartridge.
When the error disappears the faulting cartridge will be the one that has been removed
from the printer.
The cartridge will need to be replaced
Feb 15, 2011 | HP Officejet 5610 All-In-One InkJet...
Error message insert black cartridge.
Just replace the black cartridge with new one.
Nov 05, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Trying to insert new black printer cartridge
your printer will not operate with the 'color' cartridge missing you will have to install a color cartridge.
May 19, 2009 | HP OfficeJet J4580 All-In-One Laser...
I am receiving cartridge error - 50C. I have
Hi there Error 50c
This happens a lot in dell printers.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Mar 31, 2009 | Dell A940 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP color jet 2840 cartridge not recognize
    Turn the printer off and turn it back on again and see if happens now.
    Jul 12, 2008 | HP Color LaserJet 2600n Printer
    Black and color cartridges
    have one black and one color cartridge in my printer but it keeps giving me an error message:
    Oct 14, 2007 | HP Officejet 7210 All-In-One InkJet...
    HP OfficeJet t45 All-In-One InkJet Printer Logo
    183 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
