Question about Dryers
Size wire and breaker size
What size wire do i need to use to hook up a dryer and do i need to run a numeral, 3 wires total??
  • 3 Answers
It would be best to ck with your local power supplier as codes differ in different locations. the wire size you would need is a #6,use a 50 amp breaker. The wire code for most suppliers now is a 4 conductor wire as the neutral as well as the two hots have to be insulated and of course it will have a bare copper for the ground(4wires)
Posted on Apr 19, 2014
SolutionGuy
  • 331 Answers
SOURCE: Kenmore Dryer model 86683100. I need to change
Yeah, red and black go to the outside terminals, white in the center and green goes to the cabinet. What I do is hook up the red, white and black, then I place the green between the terminal block cover and the frame and screw it in tight.
SG
Posted on Apr 05, 2009
  • 83 Answers
SOURCE: Electric Dryer remains running without heat and trips breaker
Your dryer needs a new timer.
Posted on Sep 10, 2009
  • 197 Answers
SOURCE: Trips breaker: Whirlpool Duet Sport front load dryer
could be a faulty stat or element,get an engineer to test the dyer, he will check insulation on the element, could try replacing the element that just might sort it
Posted on Sep 21, 2009
SOURCE: How to hook up a 4 wire plug
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Posted on Feb 09, 2010
  • 351 Answers
SOURCE: kenmore electric dryer, model number 86873100,
Here is a sketch for both hook ups on the dryer ..
Posted on May 15, 2010
I need to know how to wire a hookup for an air compressor that takes 230V.
If you are installing a 3 prong plug you would only have 3 wires, none are color coded. The middle is your ground/neutral wire and the outer 2 are both hot so, as long as you put the middle wire onto the middle stud, the other 2 hot wires can go on either hot stud left or right they are both the same. If you are running a new circuit from the breaker box then you will need a 2- pole 240 volt breaker and what every amperage is listed for MAX breaker size on the compressor. Should be able to run # 10ga wire that is good for 30amps. The 2 hot wires would connect to the breaker and the middle wire would hook to ground in the breaker box.... You can use black or red wires for the hots and I would use green wire for the ground. Or you can run 10/3 romex wire to the outlet from the breaker box if you don't use conduit.......If you use romex the white wire will be ground/neutral and the other two the power wires it doesn't matter which goes where .....
As always, if you are in doubt about what to do, the best advice anyone should give you is to call a licensed electrician to advise what work is needed.
Mar 28, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Im at a complete loss with my dryer. It runs but doesnt heat
Check the 230v very carefully You may be hooking it up even with new wire just like the old. You have to have across the line 230
not just 230. Sounds like you need to have an electrician to check
230 across the line at the wall.
Let me know.
Leo Ponder
imufo2@sbcglobal
Jul 22, 2010 | Whirlpool GEW9250 Electric Dryer
Need to know breaker and wire size to run from panel
Compressor 12/3 with 20 amp dual pole breaker. 220 VAC
Freezer 12/3 with 20 amp single pole breaker 120 VAC
May 24, 2009 | Nor-Lake Freezer Walk In Freezer 6ft x...
240v circuit wiring to run my new Dayton Heater (3Vu34A)
On the 40 amp breaker, you should be using 8-3 w/ground. 10-3 w/ground will work on the 30 amp breaker. 12-3 w/ground is used for 20 amp circuits. Your new heater should have the electrical requirements listed in the user/installation information.
Jan 29, 2009 | Dayton 3VU34 Heater
Trying to wire a 3 wire dryer from panel box to dryer plug
Sounds like you have a 10-2 NM wire. One black, one white, one bare copper. At panel box, black to one hot terminal of breaker or fuse holder (L1). White to other breaker terminal or other fuse holder (L2). Bare copper to the grounded neutral buss bar.
At the dryer the bare neutral goes to the center terminal, the other two go one each on either side, it won't matter which way. Hot Neutral Hot. The neutral terminal of the dryer should have a wire or metal strap connecting it to the dryer frame if you are not using a four wire supply.
Oct 22, 2008 | Dryers
I have a maytag dryer Model #: MDET236AYW and I would like to change out the existing 3-wire dryer cord to a 4-wire dryer cord. Presently there are 2 wires attached to the dryer frame and 3 wires connected...
A 4 wire cord should be hooked up accordingly:
1. Black wire to either outside terminal post.
2. Red wire to the remaining outside terminal post.
3. White wire to the center terminal post.
4. Green wire to the frame screw.
Also, make certain that your breaker/fuse box is wired according to local codes. If your dryer is not properly grounded through the fuse box and the green wire is attached to the frame then, a ground wire would need to attach to the green wire and then to an earth ground. This could possibly be your 5th wire, but you need to investigate it before applying power to the dryer.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 08, 2008 | Maytag Dryers
Hooking an electrical dryer to a breaker
You will typically need a 40 amp 220V circuit for this ( check with local building inspectors).  You will need to run some hefty wire probably #8 three wire  (again check) and install the type of plug receptacle that is on the  dryer cord.
Inside the breaker box you will need a dual breaker 220V breaker rated at 40 amps.  The wire coming into the breaker box will need to be clamped in place with appropriately sized wire cable clamp where the enter the box through a knockout- available at any hardware store.
Now the big question-  why are you switching to electrical?  Gas is pretty much half as expensive as electricy  and will dry the clothes faster (usually gas dryers generate more heat than electrical ones).   Just wondering..
Oct 20, 2007 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
