Multi-colored lines on right side of tv probably 6-7 ins wide
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
Sounds like a panel fault. Contact any service technician to make it confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can see and compare it to that of your TVs' and can make sure about the fault.
Posted on Apr 19, 2014
  • 280 Answers
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Posted on Jan 30, 2009
ripleymojica
  • 643 Answers
SOURCE: Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Posted on Jun 02, 2009
  • 586 Answers
SOURCE: two inch wide vertical band spreads across half of screen
The problem is in vertical section and the faulty components are :
1- Capacitor
2- Transistor
most probably the poped capacitor must be the reason, check and replace the faulty components.
Thanks for using fixya.
Posted on Jul 01, 2009
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
  • 32 Answers
SOURCE: multi colored strip running thru tv
I'm affraid to say that your screen has got a PDP/LCD fault. Just like a tube going on a TV. This is a fault which is beyond economical repair
Posted on May 27, 2010
Thin vertical colored lines 6''with on letf and right side of tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 23, 2015 | Televison & Video
Sony tv KDL-40S4100 vertical lines on right side
Oct 09, 2015 | Sony Bravia KDL-40S4100 40 in. LCD TV
Black line inch thick right hand side
Get rid of it! I started out with the small black smoky line, went to two horizontal line, , , , I now have a 10 " line half way across the screen in two places and the rest of the line is 4-6". Contact Samsung three times on line and they responded with " we do not understand the problem, please explain. Oh yeah, TV was 2.5 years old. Never will buy Samsung again.
Mar 08, 2014 | Samsung HP-R5072 50 in. Plasma HDTV
White line on my LG 55lw5600
Just visit the site linked here. It has screen-shots to defective plasmas & LCDs. You can compare it to that of your TVs' and make sure about the fault, to an extent. It will be best I assume.
Nov 29, 2013 | LG 55LW6500 55 3D HDTVReady LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
There are verticle lines on my tv. They are about 2 in apart and 1 in wide. It starts with 1 thin line and the several colored lines join it until its an inch wide. It started on right side of tv and now...
These colors lines on the LCD screen panel are not causes by an object or human being by force hitting it?If yes,than the tv is not repairable only can be replaced the LCD screen itself.The screen it 90% important to the tv and it limited in productions,will cost the same as a new tv,if screen panel is replacing.If the colors lines came on to the tv LCD screen panel by itself.Than ur tv have a board call the T-CON decoders board is dead.This board is sitting wright in the middle botton on the LCD screen panel require replacing.Tries websites like Shopjimmy.com,ebay.com to buy a refurbish T-Con decoders board for the replacement.
Dec 07, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
