SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
Pull off bottom knob of oven shine torch down at 45degrees u will see a red plate turn off power suply and use a small screwdriver to push the plate turn power back on job done.PS Check all vents are clear to stop it over heating good luck.
SOURCE: Ariston FM22 Oven No Control decals
Go to this site www.appliancepartspros.com and look up your model there and you can order the decals or replacement knobs there.
SOURCE: Got a fan assisted gas oven. Trying to bake a cake
Temperature control with gas ovens is not an exact science. However the control should be better than you say.
Have you tried reducing the set temperature to compensate for the 'overshoot'. It may be worth a try.
SOURCE: Ariston FB 82 C IX
Hi. Did you find this manual? I am in the same situation.
Regards, Steven
SOURCE: i need to replace oven switch
Call repair clinic 1-800-269-2609. Or 1-866-822-0890 they have a lot of parts for all make of appliance.
