Question about Sony KP-65WV700 65" Rear Projection HDTV
Red screen and lines, then TV shuts off automatically
The red lines, in a curved shape, started to appear a few months ago. Now it is getting worse. The television starts going crazy with red lines until the entire television is red. It makes a loud noise and goes into standby mode by itself. It did this a few times a row so we just shut it off.
  • Sony Master
  • 5,138 Answers
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Posted on Jun 19, 2009
Vertical red lines on screen
try a dif game and send me a msg at kickop1@ymail.com
Jun 27, 2009 | Microsoft Xbox 360 Console
The screen turn completly red after about 20 min being on
Usually that is a sign that your red picture tube is ailing. However there is a chance that it can be adjusted out, at least buy you time worst case.There is a voltage control in the front of the TV, you have to remove the bottom front half of tv to get to it. Some Sony's have 2 screws hiding at the bottom of set in front hidden behind 2 plastic covers,others just have screws along the backside.Be careful there are wires to front panel attached so remove slowly and leave wires on just move it out of your way..Once you remove that there is a small access panel to take off. You will see the voltage control (small plastic square with 6 knobs) The top knobs are focus controls for each tube the bottoms are for voltage adjust. The far right knobs are for red.So you can turn the red voltage control SLOWLY to the left,this will reduce voltage.Reduce until you see the red lines disappear. If you go too far one way or the other with the voltage control the tv will shut down and you'll waste time readjusting and turning set on until it stays on. If you can't adjust it enough to get all the red out without shuting down tv tube is in too bad of shape.
Apr 27, 2009 | Sony KP-65WS500 65" Rear Projection...
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
Apr 21, 2008 | Philips 42HF7444T 42 in. Plasma TV
Red distortion
it sounds like your IR board is going out, its easy to replace and is inexpensive usually about 10.00 plus tax and shipping, and very easy to install, its one of the few parts you can buy for these models outside of the 479.00 dollar control box.
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Red screen
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Nov 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
HELP Please. Symptoms seem so similar to this unit.
This sounds as if one of your convergence IC's has shorted out. There should be 2 large black IC's on a heat sink, probably labeled STK392-040. There is a small fuse next to each IC that looks like a small resistor. The IC that controls red-red-half green is bad, leaving the blue where it should be. Replace that IC and its fuse and your picture should return to normal.
Jun 17, 2007 | Samsung PCN5425R 54" Rear Projection...
Toshiba 42wh36p problem
you tv problem intermittent the problem is in the color circuit, vertical circuit.have a tech check your tv for repairs.good luck.
May 18, 2007 | Toshiba 42H83 42" Rear Projection...
Red Horizontal Lines
they gona get worse to dead circuit, a small capacitor (problably in the neck board) is bothering you, get a tech now that he can see the problem, gonna be cheaper now....good luck ps some times the picture say to the tech was going on
Aug 05, 2006 | Sony KP-51HW40 51" Rear Projection...
Sony KP-65WV700 65" Rear Projection HDTV Logo
282 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
