Question about Mitsubishi WD-60735 Projection Television
4-8 spots on screen and now screen will not light up
  • 441 Answers
It is your DLP Chip, Very common problem with these units. Replace the chip, you should be able to buy the chip for around 200 or have it done at a shop for around 400
Posted on May 20, 2014
    Sergeant:
  • 418 Answers
Spots were defect with DLP chip, but can still use if want.
Now no picture, check lamp if burned out.
Posted on May 09, 2014
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
My garmin 60csx started to smell like electric burn. It then showed a burned spot on the screen. IF the backlit light is off then the burn doesn't show but if it is on, then it shows a burned spot in
Should it not be 12volts? If its really 250 volts i garmin shouldnt switch on anymore. And actualy use android and google maps in it. Garmin is useless anyway
Feb 25, 2018 | Garmin GPSMAP 60CSx
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
My screen is showing white spots (pixel size) How do get rid of them
On a WS-73735 the white spots usually mean a failing or damaged optical light engine.
It is a major part----Google the model number with "problems" or "light engine" etc.
Jun 10, 2012 | Televison & Video
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
PT52LCX15 sun spot on screen. Is it an easy
Panasonic servicer will have an eprom tool that connects inside the set. It removes spots. After the repair if he calls Panasonic tech line and says he removed fuzzy spots Panasonic will pay for the service. If that does not work then light engine needs replaced.
Nov 24, 2009 | Televison & Video
I have pink spots on my tv screen. do you know
you most likely have a light engine problem ocouring causing the pink spots
they usualy have to be replaced with a remanufactured light engine you might see if you got a extended warranty on the unit as this can be a tad expensive
Oct 30, 2009 | Panasonic PT-44LCX65 Television
Large yellow spot in center of tv screen
Sorry, but there is no cheap method of repair for this unless it is in warranty.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty.
Good luck.....
May 18, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Spots on screen
Spots on screen do not automatically mean you need to replace the light engine. It depends on the brand. Panasonics can reset the eeprom. Samsung can replace the DLP chip. Hitachi needs a light engine replaced.
Nov 26, 2008 | Televison & Video
Gray spots on screen on a JVC HDILA model HD 56G 787
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Mitsubishi WD-60735 Projection Television Logo
41 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
