Our maytag centennial commercial technology washing mechine fills up with water goes to the rinse cycle and doesn't go any figher I think it would be the pump as it doesn't drain so it can't go to the next cycle any ideas
  • 957 Answers
You didn't say if it washes or not I am guessing it does then when it finishes it is not pumping the water out. before u buy a new pump u should clean all drain lines and filter. be sure u check the discharge hose to make sure it is not plug. if all lines are clear then I would look to the pump as possible problem
Posted on Apr 19, 2014
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 1073 Answers
SOURCE: Washer continuously fills but drains at the same time during rinse cycle.
you have the drain pipe too low into tthe house drain pipe, raise the washers drain pipe up , you only need four inches down into the hous drain
also the house drain pipe needs to be as high as the lid of the machine before you put the washer drain tube into the house drain
you have a syphoning effect
Posted on Apr 20, 2008
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
SOURCE: Maytag Neptune MAH4000AWW will not drain all the water out.
If you are saying that after the washer has finished you are left with wet cloths and water left standing in the tub ,then your pump is broken or as was my case I opened the back and removed the pump only to find a small piece of wicker that had come off my laundry basket . It was keeping the pump from turning .I removed it put everything back in place and saved over $380.00 . I hope this helps good luck .
Posted on Apr 08, 2009
Maytag centennial washer won't fill during rinse cycle
If the inlet works during the wash cycle or start program but does not work during the rinse cycle, then it is due to fault in the program. Select another program to confirm this cycle or choose another cycle. If the fault is the same on all the programs then it can be due to the controller unit.
May 04, 2015 | Maytag Washing Machines
How do I fix my Maytag Centennial commercial technology washer.
No agitation? first use a meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good. now take the original hose tube and plug one end and blow into it the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? sometimes they get busted open or a pin hole and release air causing the water switch diaphram to not open. if both check ok then next the motor coupler or belt if belt driven. check with a multi meter for continuity the door switch, and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator.
Mar 28, 2015 | Maytag Washing Machines
My washer want spin run water want its Maytag centennial commercial technology model number mvwc7esww it run water for a seond
the pressure switch has failed or its vacuum isnt good
so its failed to detect water in a timely manner
so i would check any of the pumps traps and filters
the cold water inlet filter etc
it will be something simple
Feb 07, 2015 | Maytag Washing Machines
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
