Question about Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
I have a CME656AS-32F, IT WON'T HARVEST - Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R...
  • 100 Answers
If your cme 656 wont harvest, most common prooblem is your sump level control or wire harness. check to make sure your water valve isnt leaking thhrough
Posted on Apr 23, 2014
Have a scottsmanc1448 ice machine shows codes 1 an an 2 longharvest cleaned all water sensors descaled machine works threw all cycles water flows over both curtain coils ...
ok, what you have not told me was the temp of the ice plate. If you have an inferred thermometer now is a good time to use it. what is the Temp of the plates or ice collection try. Ice will never collect if it is not below zero C. 32F my guess is it must be below 28F. you need some kind to thermometer.
Dec 09, 2014 | Kitchen Appliances - Others
Refrigeration code on scotsman ice machine model cme506as-32f.What could be the cause?
Unit is off& Refrigeration diagnostic light is on or blinking. Possible Cause,( Low discharge or long freeze cycle. Probable correction, if the Refrigeration light is glowing steadily there is a probable refrigeration problem.) 2. Possible cause. Harvest problem. Probable Correction. If refrigeration light blinks once and repeats, Look for a harvest Problem.**On Controllers 17-1 and higher, This also indicates that cubes were (sensed) by the bin controls. 3. Possible Cause. Hot gas valve failure, Probable Correction. Check hot gas valve operation. 4. Possible Cause, High Discharge Temp. Probable Correction, If the refrigeration diagnostic light blinks 3 times and then repeats, check for a reason for high discharge temperatures. 5. possible Cause, Harvest problem. Probable Correction, Controllers 17-1 and higher, if the light blinks 2 times and repeats, check for a harvest error- no cubes sensed. 6. Possible Cause, Unit dose not go into harvest - exceeds maximum freeze time. Probable Correction, Push and release off button. Push and release Freeze button. Check operation. next Push cube size float down and check operation. 7. Possible Cause, Exceeds maxi harvest time. Probable Correction, Check for cause of long harvest cycle. Try not to put any gauges on system until you have to. Every time you do you loose refrigerant out of the system.
May 02, 2014 | Kitchen Appliances - Others
Sce170a-1a wont harvest
This machine has a cube size control. Which tells the machine when to go into a harvest. there is a harvest switch did you try to force it into a harvest and if you did, did it harvest. depending on ambient temperature from start of freeze cycle to harvest it should be making ice every 15 to 18 minuets and then go into a harvest. so start the ice machine and time it , run it for 18 minuets and force into a harvest. after ice drops check the ice bridge thickness. Bridge thickness should be about 3/16'' the ice dimple must not be DEEPER than 1/16". If this is good then we need to look at what is not working to harvest ice. The cube size control is a reverse - acting thermostat that controls the start of the timed freeze cycle. It must be set properly to prove the correct size cube bridge. When it is closed, an indicator light on the control board will be on. If you force it into a harvest and it harvest the ice with no problems and the ice is at the right thickness then replace the cube size control, but if dose not harvest the ice and you see the ice is at a good thickness and not to thick because if it is to thick it will freeze to every thing and will not drop. SYMPTOM. Unit freezes, but will not try to harvest. POSSIBLE CAUSE: Cube size control will not close; to check: Unplug water pump, switch unit OFF and then ON, in about 2 minutes the timed freeze light on the control board should be ON. PROBABLE FIX: If timed freeze light does not go ON, replace cube size control. SYMPTOM #2: Timed freeze light glows, but after 4 minutes unit dose not power hot gas nor purge valves Then replace control board.
Dec 15, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Icemaker wont harvest
if you press the arm that slides out to feel the ice all the way in three times within a few seconds, this should start a harvest cycle. If it does, then you know it can cycle and you have a temperature issue.
your ice can freeze even at 25 degrees, but it won't harvest unless it is getting to about 8 degrees or colder, so check the temps in the freezer
Apr 17, 2012 | GE WR30X10093 Refrigerator Icemaker Kit
I have an American Harvest Bread Classic II. It sounds like it is working but the paddle doesn't spin. I can manually make it move and the drive shaft I can manually move, but it won't do it on...
your belt has probably broken, unplug your machine and turn it on its side and try to remove the bottom panel. Usually held on my phillips head screws. If your belt has snapped then you will need to replace it. I have never heard of American Harvest machines so it might be difficult to find a replacement. I have good used machines for sale if you are interested. My email is daryl441@msn.com
Sep 02, 2011 | Kitchen Appliances - Others
Won't let me harvest my crops and by the time it let me they have all died. Sometimes it won't let me go to my other farm.
Sorry to hear that my friend... I'm willing to help you kindly me add me in ur FB account so i can visit regularly ur farm... relax and enjoying ur farm... Kindly ask to ur FB friends for assistance... Have A lovely day!
May 28, 2011 | Computers & Internet
Not making ice on a frigidaire side by side model FRS6LR5EB6 refrigerator
Remove the cover of the ice maker and look at the main drive gear. Look close. If a tooth is missing that is the problem. It could be a bad water valve also. Always check the cheapest thing first. Replace the ice maker last. Make sure the coils are clean around the compressor area. Ice freezes at 32f but the ice maker don't harvest till 25f. If you have a filter you need to change it out if you determine you need a water valve. Try adding water to the ice mold and see if it harvests a batch.
Mar 22, 2010 | Frigidaire Refrigerators
Icemaker wont make ice.
ICE MAKER 101
If the temp inside the ice box is 25f or less in the freezer the mold thermostat fires up the ice maker and it goes into harvest. At the end of the cycle it powers the water valve for 7 seconds. Either your water valve is bad or your ice maker. Keep in mind ice freezes at 32f but ice makers don't harvest till 25 f. If the coils beneath the box are a tiny bit dirty this could kill the efficientcy of the box.So make sure the coils are nice and clean. That in itself could make the ice production start again. reamore at the above link.
May 25, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
97 explorer starts and runs fine above 32f but will turn over all day but not start when below 32f
I had the same problem with my explorer. I found that the battery needs replaced and I never had the problem again.
Apr 11, 2009 | 1998 Ford Explorer
Scotsman CSW45 15" Ice Maker with 26 lb. Ice Storage Capacity, 44 lb Ice Production per Day, Drain R... Logo
114 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
