Question about Crafts & Hobbies
There is a high pitched tone after using sakura av 200t amp for 2 hours
It starts quiet when you turn it on, but develops a tone after using the amp for about 2 hours.
  • 119 Answers
SOURCE: High pitch noise
what you are hearing is the mechanical vibrating of coils & or transformers in the tv. 1st and easyest is to hot glue the parts that is making the noise down. if that does not work, removing & reinstalling the part is next. the last is replacement. the most likely parts causing is the 1. horizontal linearity coil, 2. the run or switch mode transformer, or 3. the flyback transformer. good luck.
Posted on Jan 09, 2007
  • 11 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Posted on Jan 15, 2009
bridgesdean7
  • 41 Answers
SOURCE: high pitched ear piercing tone when turned on.
sounds like you have a crossed wire somewhere
Posted on May 25, 2009
  • 29 Answers
SOURCE: Extreme high pitch crackly whine
yes bad fly or hozoutput
Posted on Aug 19, 2009
  • 366 Answers
SOURCE: high pitched noise
worned out drive belt or defective pulley!
Posted on Sep 10, 2009
Hi, Toroidal transformer in Sakura AV-200T input is 220v I need 110v Thanks
Hello shole135, Hi, you need a 110v to 220v step-up transformer with 200 watts power specification. you can visit your local hardware store and find one. Don't replace the toroidal transformer.
Dec 02, 2010 | Audio Players & Recorders
Constant beep even while driving and when i turn it off it still beeps unless i disconect the interior lighting fuse and plug it back in fuse # 8 i believe. if i leave the fuse out it makes a wierd sound...
1995 GrCher Orvis - I have now just started with the same problem. An incessent loud high pitched alarm sound. Identical fuse, ignition on/off, and ticking issues. Can start jeep, warning sounds as normal followed by incessent tone, I can remove fuse to get quiet, but then when I close the door I get the identical alarm sound, but with a slight pause. Tone. Tone, Tone, etc. I can't figure. Tore through all components of dash: to learn that the alarm seems to emminate from the transmission floor area, and is not in the instrument panel (f up #1) nor is it behind the dashboard (f up #2). I'm stuck now... Anybody got something for me? Is it a transmission warning?
May 28, 2010 | 1995 Jeep Grand Cherokee
High pitched ear piercing tone when turned on.
May 19, 2009 | Car Audio & Video
High pitched tone comes on whenever radio is turn on
Hi,welcome to fix ya. if this is a bose system you have a bad amp behind the rear seat they short out inside and cause the speakers to emit a high pich squeel. you can buy these amps on e-bay pretty cheaply or send it to bose for repair .
Nov 30, 2008 | 1994 Acura Legend
High pitched noise
there may be abreak on the av board . is it doing on cable,dvd another source the front panel jacks sometimes develops breaks sound like you may need a tech look at it
Nov 19, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Home phone giving a high pitched dial tone .
This normally happens when the exchange junction box nearby has some problem... do call the line man to clear the problem
Feb 18, 2008 | Uniden Cordless Phone
High=pitched hum
Hello, Using appropriate safety precautions, you can try prodding the various suspect parts (flyback, deflection yoke, other transformers), even lowly ferrite beads, with an insulated tool such as a dry wooden stick. Listen through a cardboard tube to try to localizing the source. If the sounds changes, you know what part to go after. Once you have located the guilty party, some careful repositioning, a strategically wedged wooden toothpick, or a dab of RTV silicone or hot-melt glue may keep it quiet. Best regards, Arpi
Apr 25, 2007 | Sony KP-53V35 53" Rear Projection...
Crafts & Hobbies Logo
76 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
