Question about Kenmore 24902 Top Load Washer
Hot water only filling my Kenmore series 80 . I replaced my valve and still the same problem.
There is a slight buzzing sound coming from the rear top
  • 2,509 Answers
Swap the wiring to the valves, that will tell you if it's the valve or control board. You should/could also measure the voltage across the valve when it's supposed to be operating. If it's line voltage the valve is faulty, if not it's likely the control board. If the one you put in is new and tests ok then it's the control board feeding the valve, probably a thyristor or similar switching device faulty. If you aren't qualified BE CAREFUL THERE ARE HIGH VOLTAGES IN THAT AREA
Posted on Apr 19, 2014
  • 2 more comments
  • Times Scott Behnke
    Times Scott Behnke Apr 22, 2014
    I swaped the wires and the washer has only hot water...
  • W.L. Apr 25, 2014
    Have you measured the voltage across the valve when it is supposed to be operating, (it is AC) and compare with volts across the working side? If low trace wire back to control board and identify which connector on board it goes to.
    Times Scott Behnke Apr 28, 2014
    Ill try the voltmeter. I swaped out the control board. Same result. When I turn the temp selector to cold, The water stops filling and there is a buzz coming from the valve.
  • W.L. Apr 29, 2014
    Whatever is driving the valve is faulty maybe there's a relay.? Did you trace the wires back?
Kenmore 80 series washer. Agitates immediately and does not fill
it sounds like the water valve is bad,the water valve level(sm. med. lg.)controls the water valce-mike
Jul 17, 2009 | Kenmore 24032\24036 Top Load Washer
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Kenmore 70 Series will not load hot water
It sounds like need to make some voltage checks on this job. When you set the fill cycle to hot & start the machine do you hear the valve buzz? If you do then the valve is causing the problem.
Feb 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 70 washer doesn't fill
check your incoming water supply, the buzzing sound is coming fromthe waterinlet valve , soundslikke its trying to fill. possible that the valve is no good as well,
Nov 23, 2008 | Kenmore 22422 Top Load Washer
Hot water wont shut off
solenoid valve is jammed open
replace
Mar 31, 2008 | Kenmore 24902 Top Load Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Kenmore 24902 Top Load Washer Logo
65 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
