Question about Dell 3010cn Laser Printer
Toner cartridge stuck dell 3010cn - Dell 3010cn Laser Printer
Corysf62
  • 188 Answers
SOURCE: Dell 3010cn printing problem
This printer problem is usually fixed by one of the following two solutions.
1) The Cyan cartridge is not seated 100% correctly. If the locking handle is not seated correctly, the printhead is obstructed from properly developing the the black developer at the extream right hand side. When reseated, the light can then see past the handle and place the image properly.
2) The printhead is dirty ( usually toner dust) and needs to be cleaned. To clean the printhead, open the front cover, pull back on the blue handle on the right hand side. This opens the cover to the cleaning wand on the right hand side of the printer. Gently pull the cleaning wand ALL the way out, and then slide back in ALL the way. Do NOT just move the wand back and forth. this will just push the debris around. The wand is designed to move across the printhead in only one direction. When you pull it out to its full extent, it is lifted up so that when you push it back, it is actually above the glass, not on it. When it reaches its full inward position, it drops back down to go over the glass again from left to right.
Make sure that you change this cleaning pad each time you change the imaging unit ( a new pad is included with the new drum).
Important note: If cleaning the printhead works, but then the print fades out again after a short period of usage, a more serious problem exist in which one of the photo developers is leaking. This is not a user replaceable part. The color of the defective developer would correspond to the color of the cleaning pad after cleaning.
Posted on Oct 03, 2008
ikechinedu
  • 184 Answers
SOURCE: How do you remove toner cartridge from a Dell
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Posted on Apr 21, 2009
  • 6 Answers
SOURCE: Dell 3010cn white stripe
on the 3010cn open from cover, follow instruction for pulling up the lever and sliding the bar out of the side repeat the slide motion 15 to 20 time. this action cleans the printing plate and will elimiate the strip. the strip is caused be toner leaking on to the plate it the strip returns repeat the steps.
Posted on Dec 01, 2009
  • 1121 Answers
SOURCE: Need to change yellow print cartridge -- can't go through menus
these syte explain how you can reset problem, http://www.zinetic.co.uk/video/dell3010drum.aspx
Posted on Jan 16, 2010
Testimonial: "Your solution let me know I need to buy a toner kit for the Dell 3010cn printer. The YouTube was particularly helpful for removing the external chip. "
  • 150 Answers
SOURCE: how do i replace drum cartridge?
pull open the front cover lift up the top cover lift up the blue handle on the right pull the blue handle in the middle up that is the drum unit steven 818-888-0006
Posted on Apr 27, 2010
Were is the toner cartridge located
Hello, The toner/drum cartridge in behind the front cover. I have put you a website to get a manual that explains where and how to change the toner.
Product Support
Click up there
Please rate my answer, thank you.
Sep 15, 2014 | Dell 3010cn Laser Printer
We have a Dell 3010cn printer laser and it has an error message saying "reseat fuser". We do not know what this means. Please help!
Hi
The "fuser" uses heat to melt the toner-ink onto the paper, to "fix" the ink to the paper.
Open the printer, remove the cartridge, and make sure that the fuser is _exactly_ "seated" into its socket. Replace the cartridge, and try againn.
Otherwise, take the printer to a qualified technician.
Jun 02, 2011 | Dell 3010cn Laser Printer
I wish to replace the black toner cartridge in the Dell 3010cn. How do I gain access to it. There is easy access to the cyan cartridge at the moment
if you want to replace black one only you should follow these steps Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
plz do rate the solution if got help
Nov 25, 2010 | Dell 3010cn Laser Printer
Error message says Replace drum cartridge and I'm not sure what that is or what to order
Go to
www.internet-ink.co.uk/dell/dell-toner-cartridges--p4866 This will tell you all about the drum. Then check out other sites where you might find it cheaper.
Apr 12, 2010 | Dell 3010cn Laser Printer
Where is the small memory chip located on the drum cartridge of the dell 3010cn
hELLO THERE :
On the left side there's a board marked "LEFX"
and nearby on the frame is a label with the
FCC ID number. Running that number thru the
FCC database yOU CAN FIND the documents and pictures
submitted by the testing agency.THESE ARE VERY Very informative.
There are two coils -- one on the right end of the
toner cartridge and looks like a ferrite magnet
(but isn't) and the other is on the frame and
aligns with the toner. (there is another set
for the belt/drum unit) These are coils which
are excited by a 125kHz signal and have a chip
in their center. [cue dramatic music] It uses
RFID technology. In fact, the coil in the toner
cartridge is referred to as the "tag".
Jan 14, 2010 | Dell 3010cn Laser Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Mar 29, 2009 | Dell 3010cn Laser Printer
Dell 3010CN Color Laser Printer is leaving vertical smudge/bleeding. Is there a toner dump box to empty? It is just cyan streaking.
Try a new Cyan toner cartridge. If nogo, will need a new transfer roller or transfer belt (I used to work on these printers but forgot if they use a belt or not... I will check on the DCSE site and post back)
Jan 05, 2009 | Dell 3010cn Laser Printer
Colour Printing jams in Fuser
Have you tried replacing the non standard toners with different ones?
Aug 11, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Laser Printer Logo
55 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
