Question about RCA RT2500 System
How do you reset the system (RT 2500 ) - RCA RT2500 System
    Problem Solver:
  • 7 Answers
Unplug and hold the power button while turning unit on. it will start back in demo mode.
Posted on Mar 18, 2010
Want to reset my xbox to new
There are different codes to insert at the system info page to reset your console to factory setting, depending on your console it may or not may work.
heres 3 examples, buttons has to be entered in sequence, directions are for the d-pad:
LT RT X Y LB RB Down Y Up Down Down Down Down Down
LT RT X Y LB RB Up Y Y X
LT RT X Y LB RB Up LB LB X
Jan 09, 2014 | Microsoft (X-Box) P5F-00001 Xbox 360...
Instrument panel says check rt rear tire pressure. Yellow light on. Pressure fine. How do I reset? 2008 gmc 2500 he crew
The sensor is a part of the valve stem. It is a radio..powered by a battery. The battery may be dead, requiring a new sensor. Also possible that your tires have been rotated and the shop did not reprogram each sensor to the proper wheel position. Check your other tires first, then go to a shop that can test that all sensors are functioning properly.
Nov 20, 2013 | Cars & Trucks
Need a manual for rca rt 2500 receiver,don't know how to program radio stations manually can u help me thanks Darryl
Did you try "PAC PARTS"? But I think RCA stopped selling parts! Might try a search with the model#...
Apr 23, 2010 | Audio Players & Recorders
I have a 2500 chev truck 5.7 ldr engine does not fire on rt bank i put new injectors in still same problem
You mean no fire/spark. replace your distributor cap and rotor. If your injectors are not pulsing, then it may be computer related.
Feb 16, 2010 | 1995-1997 Chevy 3500 Truck Ignition...
Reset family setting password
Here's what you need to do:
Turn on your xbox, go to System Settings. From there go to Console Settings. A window should appear that asks you for your password. If you don't know your password, then make up something. It will tell you your password is incorrect, click Reset Password".
You'll need to type in: YrYa
If this fails, then you need to follow these steps to reset your factory settings.
Turn off your xbox. Take your hard drive out (the bulge on the side of your 360. It says HDD on it.) by pressing the gray button, and sliding the piece out. Turn on your xbox, go to System Settings - Console Settings - System Info.
Press these buttons IN ORDER:
LT RT X Y LB RB Y (using the left joystick) go right ONCE A
After all of this is completed, a window should appear asking you if you would like to reset your system settings, press yes!
After all of this is completed, you'll need to turn your xbox off, put the hard drive back in, and turn it back on.
I JUST had this problem, and this is what tech told me to do... and it worked.
Good luck! Down with passwords!
Jan 19, 2009 | Microsoft Xbox 360 Console
RCA RT 2500
Try unplugging it and pluggingg it back in. That works for me.
Good Luck
Jun 27, 2008 | RCA RT2500 System
Rca rt 2500
do you have antennas hooked up to the back? if you do, make sure they reach a high place.
Feb 26, 2008 | RCA RT2500 System
Power cord for a rt 2500
Sandworms, that is the exact problem I had after a power out. It doesn't look the same as ducast's problem though. I posted the same solution in another thread. Here's hoping it works for you too.
When the red LED on the power button would glow, but it wouldn't turn on. Try unplugging it and plugging it back in repeatedly and it will eventually turn on. If that doesn't work try moving it to another outlet then try plugging it back in and out.
Oct 29, 2007 | RCA RT2500 System
RCA RT2500 System Logo
575 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
