Question about Toro TimeCutter Zero Turn Lawn Mower Hourmeter Kit 1129763
Engine wont start
New battery,even a jump start wont crank the engine
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
Make sure wire from battery to starter is connected and there are no problems with wire ( I.e. no missing insulation, cuts and connection to starter is secure.) Also starter may be bad.
Posted on Apr 19, 2014
Tip
How to tell if the battery is bad.
A bad battery can either take charged but dishcharge itself or it wont take full charge or it will charge but doesn't provide enough current to crank the engine.
Even new battery can be damaged if left uncharged for a period of time. If the car will not crank because the battery has been drained maybe by playing the radio too long. Jump start the car and let it charge. Or even better use a battery charger. Do not wait till the next day to jump start it because the battery will inquire damage. If the car was ok then all of the sudden it wont start in the morning and you know there is nothing in the car draining it, That means the battery has an internal short. It needs replacement. It will charge again after boosting but it will give you same problem over and over. Whats more the computer can be damaged by too much jump starting. It can also be damaged by a bad battery. If your car wont start and it has roughly 12.6 volts which is the voltage for a fully charged battery, that means the battery is also bad. In eliminating the battery as the culprit all connection must be clean and dry. Grease on the post used to prevent corrsion can lead to poor contacts.
on Jul 22, 2010 | Honda Accord Cars & Trucks
Wont start new starter good battery
Even though my battery showed a good voltage it wouldn't crank the engine in my grand prix anymore. It wouldn't start with a jump box either. As soon as I put in a new battery it was fine.
Apr 21, 2014 | 1998 Pontiac Grand Prix
It won't start: new battery, have lights, it just clicks when you turn the ignition switch
you mean it wont crank, it must crank to start.
1: bad starter system
2: weak battery even a new battery can be weak.
if you dont charge it first.
or if it starts ok then wont later, that means cars charge system failure.
can you jump start engine? with jumper cables.
that be a big clue there, proving starter works but battery was weak.
if the battery is fully charged.
you can hot wire the starter solenoid, (tiny terminal)
if car cranks now, the key start wire is failing.
A/T or M/T tranny? both use different path here....??????
if you cant hot wire it, then that means the stater is bad
the cables bad or the battery is not really connected.
or possible the engine is seized, can you hand turn over the engine at the front crank bolt (CW , facing rear, in neutral)
if not motor is seized.
some times even the starter and rig gear can be seized.
the starter can be bench tested. too.
http://www.fixkick.com/nocrank.html
Sep 19, 2013 | 1988 Suzuki Samurai
Car won't start without a jump but battery okay
wont crank or wont start.??
no car starts , if it cant crank. (unless push starter (M/T magic)
that is not a trans sensor its the PRN switch.
ill answer for, wont CRANK !
it wont crank even with a good battery (charged) or jump started.
1: bad start
2: bad wires to same.
so hot wire the starter small wire, the key start line is tiny.
cranks. , starter good, no crank starter bad or cables bad.
if it cranks hot wired, then the key line is dead.
easy, huh?
Feb 11, 2013 | Suzuki Forenza Cars & Trucks
I have a 2000 Acura Integra LS. The car started this morning and now it wont start. It will turn over and its getting gas, but still wont start up. I put in new spark plugs and still the same result. any...
A few things you may want to try;
1. Clean the cables on the battery, even if they don't appear to have much corrision it doesn't take much to prevent the alternator from charging the battery at it's peak level. When you're finished try to start the engine.
2. If it still will not start, try to find someone to give you a jump. Even if it's cranking it may not be providing the minimum speed needed to allow the engine to start. Having atleast the Minimum, " Cold cranking amps ", required by your vehicle is crucial, especially in cold/cooler weather.
If the vehicle starts with a jump you likely have an issue with your battery. Many parts stores will hook up a diagnostic machine to check your battery, alternator, and some will also check the starter for FREE.
I hope this helps you get your car going.
Jan 26, 2011 | 2000 Acura Integra
I have a 91 fzr 600 recently did oil change, spark plugs,didnt ride bike for 2 days then went to ride it today and wont start, thought it was the battery so i jumped it and it started but started running...
you will need to try a new battery, unfortunatly sometimes jumping of a larger battery can spike the regulator, so when the new battery is fitted put a mulimeter across the battery, should read just over 12v engine stopped and rise to 13.5-14v with the engine running.
Jun 10, 2010 | 1991 Yamaha FZR 600
1992 Crown Vic wont crank
Check the starter solenoid. Usually mounted on a fender well. Find by following the + battery cable.
Feb 14, 2009 | 1992 Ford Crown Victoria
1997 buick skylark wont start
Does it crank and not start or not even crank. You could have a bad starter. I would test the battery first. When it won't start try to jump start it. If it jump starts it's probably the battery. If it won't jump start it's probably the starter.
Jan 01, 2009 | 1997 Buick Skylark
Car wont start; tried jumping didnt work; batterie should be fine
How old the car and battery is?
when you jumping the car, did you start another car's engine?
Jul 27, 2008 | Honda Accord Cars & Trucks
Toro TimeCutter Zero Turn Lawn Mower Hourmeter Kit  1129763 Logo
205 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
