Canon NP 6035 Copier Logo
Posted on Jun 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aaa i have some problem with canon np 6035 copirer i can't change languige to english  can U help me ?
Sid
Level 3:
  • Master 483 Answers
  • Posted on Jun 19, 2009
Sid
Master
Level 3:
Answers
483
Questions
Helped
191387
Points
1547
Here ya go:
What you will see
The printer display is not in the required language.
What to do
To change the language on the display back to the required language, do the following:
Steps Action 1 Power the printer off and back on. 2 Press the down arrow button () four times. 3 Press the button once. 4 Press once. 5 Press once. 6 Press once. 7 Press the left arrow button () or right arrow button () until you see the desired language. 8 Press the return button (). 9 Press once to save the new setting
HOW TO CHANGE THE LANGUAGE FROM GERMAN TO ENGLISH canon 6035
www.retrevo.com/
Try this link to download the user manual this device. It has all details.
Electro help
Set duplexingunit canon NP 6035
codes e002 et e004 canon copier np6035
How to change language in canon 6035?
i think your copier is canon Np 6030. open the back cover . then you can see two
EPROM .
Servis manual 6035
6035/6050/6545/6045 service manual
Aashish canon@Gmail com
In mail Address Convert Space ( ) to Dot (.)And Mail me To All Service Manual
My canon 6035 copier displays in Dutch or German. I would like to change it to English. How do i go about it?
Hi owole2. Try looking for the settings from the copier. then look for language settings.
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
29helpful
7answers
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
1helpful
CHANGE THE LANGUAGE FROM GERMAN TO ENGLISH canon6035
camge the eprome in dc controller. first get a copy from the language you want and install it in your machine.
Change language
not sure you can????
Anyway to get into service mode,
open front door
bottom left next to green knob there is a pinhole
insert paper clip and push on switch
you should be in service mode
if not you must cheat the front door while it is open (folded paper in slot will do)
then go through the steps
once in service mode you should be able to scroll and check for language
old marine
old marine
ZJ Limited
ZJ Limited
