Question about Toshiba Qosmio F25-AV205 Notebook
Cd-dvd error at startup - Toshiba Qosmio F25-AV205 Notebook
    Top Expert:
  • Toshiba Master
  • 23,168 Answers
Faulty CD/DVD drive?
Posted on Apr 19, 2014
My laptop is showing the smart hdd error at startup. how can i disable that message? I am using hp pavilion 2000 laptop.
The SMART hard disk check has detected an imminent failure. To ensure not data loss, please backup the content immediately and run the Hard Disk Test in System Diagnostics.
Hard Disk 1 (301)
F2 System Diagnostics
ENTER - Continue Startup
For more information, please visit: www.hp.com\go\techcenter\startup
Sep 02, 2013 | HP 2000-2B89WM Intel Core i3-2328M...
I want to remove all my hardware and re install the orginal software that came with the computer
Okay, first save all documents you need etc. Then set the bootsequence in your bios as cd/dvd first and hd second.
Place dvd and startup; touch key when asked to startup from dvd.
When asked where to place windows first format c: drive. Then you start all anew.
The rest should be a snap.
Jan 08, 2013 | Acer Aspire M1610 Drivers Recovery Restore...
Windows will not start up or launch start up repair
hi,
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
May 21, 2012 | Dell Inspiron Mini 10v Netbook
My dell inspiron 1501 has a error 0xc0000011 windows failed to load because the system registry file is missing or corrupt also would not load any cd
Go into your bios and make sure that your cd drive is the FIRST BOOT device. Then load the dvd and run a startup repair.
Mar 20, 2011 | Dell Inspiron 1501 Notebook
Power caliberation error
  • Try using different brands of quality blank media, most common reason for such error's is cheap blank media.
  • Try burning at lower speeds (Highly effective).
    Disable IMAPI Service (Work's in most cases):
    1. Launch Control Panel -> Administrative Tools -> Services .
    2. Browse for "IMAPI CD-Burning COM Service", Right-click on it and select properties.
    3. Chnage Startup Type to Disabled.
    5. Click Apply and Reboot.
  • Try updating or changing your CD\DVD burning software to the latest version.
  • Try upgrading your writer's firmware.
  • If all the above fails the problem is definitely related to hardware and not software, Go ahead and get your burner laser lens cleaned by a professional.
  • If all the above fails the drive's laser might have died and you need to get it replaced.
  • Best Of Luck, do post your results.
Jan 16, 2011 | Computers & Internet
Dvd burner error
uninstall the dvd drive and reinstall it if that does not work update the firmware of the drive or delete the upper and lower filter from registry editor and DONOT FOR GET TO RESTART THE SYSTEM
Jun 23, 2009 | E-Machines eMachines Desktop PC
Laptop hp dv6000 will not recognize cd burner/dvd player
HP Pavilion dv6000 laptop PC
Did you 'turn off' the AUTOPLAY feature of the CD\DVD ? When the player "runs two times at startup", it is trying to find the program on the disc.2nd- Look in internet for HP dv6000 cd\dvd drive replacement.(If that is the ""exact match for the product"" you wrote about)
3rd.goto CONTROL PANEL>SYSTEM>HARDWARE>DEVICE MANAGER and look up cd\dvd and uninstall it. REBOOT, when your system comes back it will try to find the cd\dvd. If it does not, it is damaged (kaput!), must be replaced. If Windows finds the cd\dvd drive and reinstalls the drivers, but it does not work, then the heads are dirty or damaged.That Windows found the dvd\cd means that the circuit on the device works.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Hp cd writer cd12d
Hp cd writer does not require drivers on windows unless it is Windows 98/ME or earlier version.
a: drive error, it is an error with floppy, or floppy settings, not cd.
If floppy is present then floppy drive is probably faulty and in need of replacement.
You can bypass the problem accessing to bios setting. Usually you have to press a key on startup to start bios settings.
Once you access settings you have to change the error prompt setting. The computer will start the same but you won't be able to use the floppy.
Jun 08, 2008 | Computers & Internet
Cd/dvd rom
I am presuming that you have the correct driver for the DVD, and nothing else has changed (no new DVD software that might cause this problem by addressing the drive improperly). Nero and Power DVD can both cause problems if your DVD is newer than the software version.
Now, all that out of the way, here is the diagnosis. DVDs are much higher density than regular CDRoms. DVDs average 4.5 gb, whereas a CD is caped at 0.7gb (700mb). Thus, DVD drives have very low tolerance for ANY kind of error. Therefore, DVD combo drives are not likely to last as long as the rest of the laptop's hardware. Shock at relatively minor levels can damage a DVD drive. Often, they will still open a regualr CD, but fail to read a DVD directory. Your error code, if it is posted at startup, indicates the drive is malfunctioning. You can test it easily. Usually there is only one screw that holds it in (underneath the laptop, about 4 inches from DVD tray cover, towards the center). Turn off laptop, flip it over on a towel, and remove that screw. Tuurn the laptop over again, then insert a straigtened paper clip into the small hole in the DVD tray face. Be careful to push lightly and STRAIGHT in with this paper clip and the tray will pop open. Pull gently, and the whole DVD body will slide out. With a new or used replacement DVD or CD, reattach any hardware on your old DVD to the new one, then slide it back into the laptop 9no need to install screw just yet) Start laptop. If error is gone and DVD plays OK, insert the screw again and make your old tray cover fit the new drive (always can be done if you look closely to find the tabs and remove it gently). Sometimes some plastic will need to be trimmed with an eExacto knife to get a good fit.
Feb 16, 2008 | Toshiba Satellite A60 Notebook
Toshiba Qosmio F25-AV205 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
