Question about Dell POWER SUPPLY PE1650 275W DPS-275EB (DPS275EB) Power Supply
HOW CAN I PORER UP W/O COMPUTER?
NEED TO KNOW HOW I CAN RUN POWER W/O COMPUTER.
GROUND ANY PIN?
  • nob Jun 19, 2009
    thanks for adv. however i am confused.
    PS has 50pin connectors and there is another connector connecting DEL pc with 24 pin connector..
    which connector do you mean?
  • nob Jun 19, 2009
    pin 11 12 of 24 pin are both ground.
    pin 11 and 12 of 50 in is +12v and GND.
    pin 14 of 24 pin is GND
    pin 14 of 50 pin is +12v.
    They are not ATX connector.
  • 555 Answers
Connect PIN 11 to PIN 12.  Try that one.
Posted on Jun 19, 2009
    President:
  • 948 Answers
Pin 14
  • Dick
    Dick Jun 19, 2009
    It's pin 16 on a 24 pin connector. Forget about the 50 pin connector, that does not concern you. Computer power supplies are turned off and on by a signal from the motherboard, routed through the machine's power switch. Ground the right pin and the power supply comes on.
How do you know a computer is burnt on a golf 99?
Go to pin 4 and 5 measure the voltage together,this will determine the voltage drop, with key on engine running if it starts the voltage should not exceed .05vlts. Go to pin 16 measure pin 16 and body ground you should measure battery voltage,3_29_2012_7_06_06_pm.jpg
Mar 29, 2012 | 1999 Volkswagen Golf
Ref ASTEC power supply from old computer model SA 147-3505 I can pick up the logic 5 volts but not the +12 volts and -12 volts .FAN not energised so I guess there needs to be an elec link via the computer...
You can jumper on an ATX power supply by using a wire to connect pin 4 (green wire) to any of the grounds on the 20 pin ATX connector. The grounds are normally a black wire. You will need to put some sort of load on the power supply such as a hard drive to keep it running.
Feb 25, 2011 | Dell PWR,SUPPLY,145 WATTS,ASTEC SA150-3411...
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
1 3.3V Orange +3.3 VDC
2 3.3V Orange +3.3 VDC
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
10 12V Yellow +12 VDC
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
/PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
I HAVE POWER THROUGH THE CRANK FUSE, TO THE PCM AT PIN 76 (12VOLTS) when in the crank postion. PIN 23 ISNT SENDING A GROUND TO THE START RELAY. IF I GROUND IT THE ENGINE WILL CRANK. I HAVE CHECKED ALL HOTS...
Pin # 23 isn't going to send anything , this is an input to the PCM to signify crank is being requested . That's all just a signal for the PCM starting is being requsted . An the crank fuse doesn't have anything to do with power to pin 76 . The crank fuse B+ power comes from the ignition switch when in the start position an goes to pin # 23 at the PCM . B+ voltage from the PCM/ ABS fuse in the I/P fuse block goes to an through the park neutral safety switch to the coil side of the starter relay an on to pin 76 at the PCM
Dec 10, 2017 | 2002 Chevrolet Venture Passanger
Computer will not turn on. Possible power surge.
If the power supply is good then your motherboard must have gone bad during a surge.
Dec 26, 2009 | Intel D865PERL Motherboard
2001 jeep cherokee sport 6 cyl 4 wdr cranks want start
If the data link is not talking to the computer check your ground at the computer and at the data link connector to see if the computer is even alive ground pin 3 on DLC with the key off then turn key to the run position if it flashes the check engine codes record them, if no engine light, does the engine light come on when you turn the key on then go off? if not, check fuses if not check power for pin on computer, if it has power you have a bad computer. But TEST THE GROUNDS IT IS THE BIGGEST FAILURE For these rigs or any manufacture. check that you have power also at the DLC too. if not you need a digital ohm meter and a subscription to http:///.www.alldatadiy.com and start reading the campaigns on that vechile for computer and trouble tree for dead DLC and computer. I don't have that subscription or I could tell you more where to look, if you need anymore help let me know. Also if the crank sensor could cause it not to run the fuel pump but so can the cam sensor. You need to find out if the computer gets it's pulse for the pump at the computer if it does then you need to test them both. There are three wires a ground a colored power wire and a wire to go to the computer you can test these sensors with a meter to see if there is a pulse to each. sometimes the fuel pump gets it's signal from the coil pack so it's important to have the subscription, you can do a search for each item and test them as needed and has a wiring diagram.
Jul 26, 2009 | 2001 Jeep Grand Cherokee
No power up
You need to locate the PS_ON pin and short to ground (GND). This pin may vary depending on model and I don't know if green is the standard color for this, but it is green on the unit I just looked at for reference and it it aso shown here http://pinouts.ru/Power/atx_v2_pinout.shtml
any black wire should be ground
Dec 19, 2008 | Sparkle Power : 300W FSP300-60PLN PFC...
Motherboard
To download you're manual for the D815EEA2, please click the link below.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
You need to go to page 85.
7482c11.jpg Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G
Good Luck!
Have more questions? Please feel free to ask.
Mike
Jun 02, 2008 | Intel Desktop Board D815EEA2 Motherboard
Wiring harness on my 94 Ranger
I have a 94 Ranger XLT extended cab. Here are the power/ ground connector pinouts and wire colors as shown in the factory service manual:
Pin 1 LG/Y Radio Memory Power (B+)
Pin 2 BK Ground
Pin 3 Y/BK Power (Hot in RUN or ACCY)
Pin 4 LB/R Illumination (dims with dash lights)
Pin 5 O/BK Illumination (does not dim)
Pin 6 BK/LG Ground
From the diagrams, looks like either ground will work.
Hope this helps.
May 30, 2008 | Car Audio & Video
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 | Cameras
Computers & Internet Logo
200 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
