LG top loader now has a very load knocking sound and the cycle stops at the spin stage although the readout goes right to the end so you lift the lid and voila wet clothes
My machine is an LG 5.5 fuzzy logic turbo drum WF-T552A
    New Friend:
  • 3 Answers
Hi I'm Jerome Jacobs.appliance repair technician. It would appear that your toploader is not levelled.you also would want to open your drain pump to see if anything like a hairpin or so is stuck there.remove all debris from the pump but be sure to unplug your toploader to prevent a shocking experience.Your machine also have a selector which is in a white plastic covering it would be wise to open it to see if the plates are making contact.lastly,you may want to look at the gears situated right behind the agitator wheel.its the one attached to the pulsator/carousel driven by the fanbelt.Hope this will help you to sort out your problem
Posted on Mar 09, 2015
I've got the same problem; I had a look "under the hood" and it would appear the "clutch" system (not sure if a washer's got a clutch?) is making the noise. There's a spring pulling only halfway and then flicking back again, causing the noise. Is there any straightforward fix for this?
Posted on Nov 29, 2014
  • 2,509 Answers
Does it knock all the time? Have you tried it empty? Have a look at the springs or shock absorbers,maybe one is broken or the weight attached to the drum, is it secure and properly located? Check for play in the drum bearing by moving the inner drum side to side against the outer (and also listen to see if anything is trapped).
Posted on Apr 19, 2014
2 Suggested Answers
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Whirlpool top loader has knocking sound when it goes into spin / pump stage.
You probably have a bad bearing at the bottom of the tub or damage to the gearcase.
Dec 31, 2009 | Whirlpool LXR6432JQ Top Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
Maytag top loader stopped during spin and now won't start.
ok check the lid switch,,did it knock it out of place,,unplug and take back off ,,,
Jan 05, 2009 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing machine - knocking sound at end of cycles
Hi there is it a top loader or front? If a front loading machine it might be the concrete block has come loose under the top cover.
Thanks J
Feb 26, 2008 | Whirlpool LSB6200KQ Top Load Washer
Drain/Spin won't work unless lid is lifted up
Curdy, it almost sounds like your lid switch is loose or fractured and the lid actuator is not making the switch. Check this out first and post back...Catriver.
Oct 19, 2006 | Whirlpool LSR5132PQ Top Load Washer
Spins when it feels like it
Popcorn, sounds like you are having trouble with the lid switch. The plastic housing in which the screws hold the switch to the cabinet may have cracked, or came loose. If the lid switch is not making correct contact the result is no spin, no drain. The switch actuator on the lid itself may need adjustment. The lid switch is mounted to the cabinet on the back right side under the consol. The lid switch part number is 8054980. But check the actuator first. Catriver..post back.
Oct 04, 2006 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
165 people viewed this question
Top Washing Machines Experts
