Question about LG WD-80130F 7.2kg Washing machine
I need a PCB Board
Can anyone tell me where I can purchase a PCB Board for an LG WD-80130F #407KWTA00017 Front Load Washer.
catriver
  • 878 Answers
SOURCE: LG WD-8016C Front Load Washer leaks from the bottom
Crawls, usually all leaks are visible. Im surprised the repairman did not actually get to the source of it. Your drain pump sits on the bottom and it possibly could be the filter cap, hoses to the pump or pump itself. Another area to check is the despensor. There are a number of hoses to this which could be leaking. The bellow itself could have a cut in it somewhere along the bottom. I would call the repairman back and have him at least get to the source of the leak...Catriver..post back.
Posted on Aug 14, 2006
  • 210 Answers
SOURCE: "CD" ERROR ON LG WM-3677HW Front Load All-in-One Washer / Dryer
CD means cool down, press the pause start button, the door lock will open. It is an anti crease cycle. It mentions it in the owners manual, but it is hidden deep in the drying section.
Sgt 48
Posted on Jun 03, 2008
  • 210 Answers
SOURCE: LG Front-Load Washer WM2277HW ce sign
CE is an error stating that you have a problem with you board or possibly the stator on your unit. Either way your going to need service. You can ohm out your stator to see if it is the problem.
Check the back harness, maybe it has come loose, remove the back panel and it is the blue connector.
Sgt 48
Posted on Jun 08, 2008
  • 210 Answers
SOURCE: LG WM-2277HW Front Load Washer not working with ce showing
Sgt 48
DRACO A5OG
  • 22 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Fixed!
"LE" code Stator/Motor Error.
It was a simple fix and only cost $17.68 at PartStore.com no affiliation.
Hall Sensor 6501KW2001A
http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6501KW2001A/New.aspx
Here is the Service Manual
http://oasisappliance.com/products/lg/LGComboServiceManual.pdf
Bonus, it actually completes a wash cycle and does not stick at 6 minutes, drying forever.
Freakin service tech stated it was the Power Control Board, IDIOT!
While I was in there, I cleaned out the heater blower assembly and sensors. They were full of caked on lint and the sensors had debris all over them.
Also cleaned out all the lint and debris around the rubber seal, this will eliminate those annoying mildew oders.
Hope this helps someone, Happy New Year!
Posted on Dec 31, 2008
Wiring diagram
can you check the harnest assymble,,,may be its bitten by the rat,,,
Jan 09, 2014 | LG WD-80130F 7.2kg Washing machine
Door mechanism
this is not problem with door swicth ..kindly re main Replaced thE MAIN pcb
SE is appearing on the screen of LG washing machine
LG washing machine error code SE indicates a "motor fault" although the error code also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you are a DIYer unless you at least know how to test a motor for faults and check its connections and carbon brushes (if fitted).
Aug 29, 2011 | LG WD-80130F 7.2kg Washing machine
Main circuit board faulty
SE is 'sensor error' This could be anything from a loose wire to a faulty Hall sensor or even a main board failure......You probably need an LG technician. Your machine sounds like it's worth repairing.. Get quotes.........Good luck...Nomess
May 30, 2010 | LG WD-16115FD Front Load Washer
Operating instructions for a wd 1049c washer
go to lg's website and put in your model # and you can download the manual
Jun 21, 2009 | LG WD-1041WFH Front Load Washer
Water in and pumping out at the same time
Is it actually pumping the water out or may it be that your your outlet pipe have been placed too low in the out drain. This creates a syphon effect.
Apr 24, 2009 | LG WM-2277HW Front Load Washer
LG WM 14225FD eu code
EU --- error means ---Unbalanced load is sensed three times during a spin operation. to resolve the issue ----Open lid. Rebalance laundry load and close lid.· Check wiring harness
· Check unbalance switch
· Check circuit board
Mar 14, 2009 | LG WD-1280FHD Front Load Washer
LG Washer won't start
If you have eliminated the possibility of a faulty AC power cord or faulty AC outlet, then it sounds like your unit will need the main control board replaced. Probably a bad relay on the main control board.
Nov 30, 2008 | LG WD-1280FHD Front Load Washer
Lg wd-80130f
sounds like whoever changed the pump has made a hash of the wiring, get them back to it.
Feb 04, 2008 | LG WD-16115FD Front Load Washer
Washing Machines Logo
70 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
