Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
NEED MY ROUTER IP ADRESS CANT LOCATE MANUAL MODEL F5D9230-4
    Scholar:
  • 119 Answers
Most routers when reset use the default following IP addresses: 192.168.0.1 192.168.1.1 192.168.2.1
Posted on Jun 19, 2009
  • 256 Answers
This is from the Belkin Web Site:
Windows 2000, XP, and Vista
1. Click Start, and then select All Programs (XP and Vista) or Programs (2000). 2. Select Accessories, and then Command Prompt (2000, XP, and Vista). 3. At the command prompt, enter: ipconfig 4. The IP address (or IPv4 address is you are using Windows Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx, for example, 192.168.2.2. 5. To close the command prompt, type: exit and press Enter.
Router NetGear 49
It depends on the router, not the adapter setting, which you have not included.
Sep 26, 2013 | NetGear Universal WiFi Internet Adptr...
I have lost the security code and have a new laptop, how do i set it up to work
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Aug 30, 2011 | Belkin (F5D8231-4) Wireless Router...
I change my old fios router for a new one my computer work but not my laptop. cant seems to find the password to reset
If you have manual of the router, read what's the default IP adress for accessing router. You can also try typing the 192.168.1.1 instead of a web adress in your WORKING COMPUTER'S web browser (this is the default IP usually). You will get window with username and password (you will find username and password in the manual of the router). When you access router, you can turn Wireless LAN on/off and change all values you need. You really should read manual first, it will all be clear to you after that.
May 21, 2011 | HP Pavilion dv6000z Notebook
I cant find the ip adress on my Hp Notebook PC
Hit the start, then run, type cmd then run , at the prompt in the black box type ipconfig enter, if you need more info the that type : ipconfig/all
Apr 08, 2009 | HP Computers & Internet
I cant reset my senao eoc3610
1 ) Check if IP address is the correct address of your Gateway.
Check if you can ping.
Be sure you have your Java enabled
Some router requires a specific Browser (IE6 or IE7) and cannot respond to different browser.
Be sure to remove any Java protection from your Browser.
Check with user manual if IP address requires also a specific port number ( 8080 or other).
Be sure to Connect Router using Lan cable
2) Change your PC IP setting to same subnet as your router
Control Panel / Network settings / properties of TCP/IP define an IP address and a subnet mask compatible with Router as gateway.
3) If you are not sure of Router IP address use reset button on router back to factory default; use this to configure router.
Dec 27, 2008 | EnGenius EOC-3220 (EOC3220)
I unpluged my remote camera monitoring system and it lost its ip adress
The IP address on your camera system is probably setup using DHCP. This means that the IP address it's given will change over time. There's an easy way to find it. Log into your router, and locate an option called "DHCP Clients Table". This will list every system on your network, and one of them has to be the camera system.
If your router does not have a HDCP clients table, then you'll have to either do a network scan using something like bluesportscanner, or nmap, or to log directly into the camera system using a serial cable or something similar.
Comment back with your specific camera system model number, and I can provide more assistance.
Steven
Aug 04, 2008 | Computers & Internet
Driver help...Anyone?????
For Router drivers is not required ,U can configure though the command prompt
I can tell some configuration try it,
the default ip adress of the router will the 192.168.1.1 OR 192.168.0.1
In your Lan card configure,
1. obtain Ip adress automitically
go to command prompt----type ---ipconfig---check the ip address which ip is getting---
go to internet explorer ----type the ip address in adress bar-----------login page will get---
login as, user name admin
password admin------configure your internetip adress & DNS ip address,save & check.............
Mar 21, 2008 | Actiontec GT704WG Wireless Router...
Port Forwarding - can't access router management
normaly you can gain entry to the router
via an ip adress you would put into internet explorer
you can get the ip adress from the manual you got with the router
failing having the book then a google serach will tip up the info you need
Nov 10, 2007 | D-Link AirPlus DI-524 Wireless Router
Unable to access the router for manual setup
open a web browser and goto http://192.168.1.1 the default password should be admin and the username is admin too
Nov 09, 2007 | NetGear RangeMax WPN824 Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
177 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
