Question about Husqvarna Garden
Clutch won't disengage on my Riding Mower
When I turn my mower on the blade engages and wont stop. Whether I pull the clutch to disengage the blades or not is makes no difference. When I turn the mower off, I can hear the clicking each time I pull the clutch up and down to disengage and engage the blade, so I don't think the switch is bad. Any ideas?
    Sergeant:
  • Husqvarna Expert
  • 187 Answers
Sound like the electronics and the clutch activator are working. However, it sounds like the clutch pads are not disengaging.
They make have gotten hot and froze to the pully housing or their may be some foreign object caught up in there.
Take the belt off the clutch and see if the pulley housing spins freely (machine off of course).
Posted on Mar 20, 2015
    Guru:
  • 145 Answers
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Posted on Apr 19, 2014
2 Suggested Answers
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
The mower blades are engaged at all times. The switch that disengages blades does not work. A safety issue exists. What can you advise?
Sounds like the switch is defective and must be replaced..in the meantime...locate the wire connecting to the electric clutch fro the bad switch, shut the mower off and disconnect the wire from the clutch..you can operate the mower when not using the blades....just remember make sure you shut it down before attempting to pull the wire off the clutch..this is only a Temporary fix...good luck..
Jul 28, 2015 | Husqvarna YT48XLS 48 inch 24 HP Kawasaki...
Blade will not disengage on Craftsman GCV160 lawn mower.
that type mower the blade always turns when running .
May 07, 2015 | Craftsman Garden
What causes fuse to blow every time I try to engage blades?
To engage the blades is it a knob to an electric switch that you pull?
If so does the wire from the switch activate a electric clutch?
Is the wire damaged and shorted to the frame, is the clutch shorted. If you provide the brand name and model number I might be able to find a schematic for your mower.
Video shows an electric clutch but yours may be different but this should give you an idea of where to look. Riding Mower Electric PTO Clutch Won Engage When Hot Problem Fix
Oct 02, 2014 | Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Blades wont engage
check the clutch if it engage then check the cable and belt to if it works make sure all the bolts are tight. usually the belts is too loose or if its a clutch drive maybe the clutch doesn't engage or worn out.
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Aug 15, 2009 | Garden
My blades wont engage and just hear click sound?
No permanent solution, but you probably can get by once by "riding" the clutch engagement lever - pushing it only part way forward and holding onto it.
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
303 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
