Question about Pioneer VSX-D307 Receiver
Possible overheat my receiver was playing and started cutting out.Now it plays at a very low volume
  • Pioneer Master
  • 3,289 Answers
Check for crushed , damaged and shorted speaker wires at the terminals of both the amp and speakers and over the entire length of the wires. Clear any shorted connections and replace damaged wires. If still persisting, you may need to have it serviced.
Posted on Apr 19, 2014
I set the volume to 40. After a little while the volume starts dropping down. If you do not turn the volume back up the volume will eventually go to zero all by it self and turn off the system.
HDMI Audio drop out? - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > HDTV Forum
Sep 21, 2005 - My Panasonic TH-37PX50U plasma has an audio drop out problemwhen .... The drop out occurs on both TV sound and receiver sound. ... very littlebass effects when playing DVD's through the HDMI cable when I compare it to ....Most noticeable when I turn down the volume control on the set top box (and ...
Dynamic volume problem : Ask Audyssey
https://audyssey.zendesk.com/.../20013893-Dynamic-volume-problem
Apr 8, 2011 - it appens only when dynamic volume is ON (day, evening or midnight) . the audio signal of the TV is on a optical Toslink cable and it ... and so it drops thevolume to make sure the sound will not be too loud. ... April 11, 2011, 12:40 AM .... Setthe audio setting on the receiver to Stereo vice Surround Sound.
How do I stop my surround sound system cutting out? - TV DVD HDMI ...
ask.metafilter.com/.../How-do-I-stop-my-surround-sound-system-cutting...
Jan 21, 2009 - When the volume is at higher levels, all but the center speaker cuts out..... That is why I just turn down the TV's speakers to 0 and listen to things from thereceiver. ... notice that the sound is coming 40ms later or earlier than the video). ...system), and adjust the A-V delay on the receiver until the audio lag is ...
Jan 06, 2016 | Audio Players & Recorders
When raising volume deck cuts-off
Sounds like an overheating issue. Most car receivers have heat sinks at the rear to dissipate heat, but if there is little or no rear clearance for the unit the heat may build up and the unit goes into a self protection mode and shuts down.
Sep 01, 2015 | Car Audio & Video
My receiver started making popping sounds and cutting out for seconds at a time. Checked all connections can't figure what's wrong.
It sounds to me like you have a problem with one of the amplifiers and the speaker protection is activating. If you are playing at a low volume setting and this is happening, the likelyhood is that one of your bias levels is out of tolerance. If you don't know what you are doing, get someone who does to check the DC voltage on your speaker outputs without the speakers connected. The bias control should be set to 0 volts on the speaker outputs.
Mar 04, 2015 | JVC RX-6042 Receiver
If fan fails will protect come on
If you are playing at loud volume levels , the power amp will overheat without a fan and you could VERY well get a major failure.
I'm not sure about a thermal protection circuit on Overheat
May 24, 2014 | Teac AG-V8060 Receiver
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
Sleuthing a 300/4 low-ohm issue. 300/4 amp history: unknown. just connected today whole system yesterday/today: head unit, 300/4(to 4 polk 6.5" component speakers brand new) 1000/1 (4-W3's),...
Are you sure you getting enough power to push everything. I have seen when the voltage is too low coming in, the amps will shut down so they don't overheat. Once they've cooled off and the volume level is lowered they will kick in again. Low voltage and a heavy draw will create massive amounts of heat.
May 24, 2011 | Jl Audio 500/1 Car Audio Amplifier
Everytime i try to play my system at full volume it cuts out then keeps playing and carries on doing this to i turn it to a certain volume
First of all find out the recommended speaker impedance for the receiver. Then find out the impedance of the speakers you are using along with it.
Simple rule is the speaker impedance can be higher but not lower than the recommended value. If it is so the receiver will run hot and if you turn up the volume higher it will run even hotter and then the protection circuit will cut off the Amplifier output to prevent burn out of components. Even if you have one defective speaker this cut off can happen. To confirm defective speaker -- disconnect one speaker at a time and turn on the amplifier and play it at cut off volumes.If by disconnecting one particular speaker the Amplifier does not cut off -- THAT SPEAKER HAS A SHORTED COIL and needs replacement.
Apr 03, 2011 | Philips Audio Players & Recorders
Hi there .......my sa gx303P stereo amplifier/tuner technics ...the cooling fan for the power amplifier works only on a somewhat strong signal .....if you play soft music at low volume the cooling fan...
These units are designed to only run the fan when necessary. If the unit is overheating, there is a problem in the detection circuit. This is a relatively inexpensive repair. If you are getting overheating when running at a low volume, it suggests that the speakers are not matched to the amp. In other words, the amp is expecting an 8 ohm load and is being presented a lower ohm load. This makes the amp work harder and generates more heat. Check the speaker wires and make sure that they are not frayed or crossing in any manner. Also, verify that the rating of the speakers is correct.
Update this with what you find.
Thanks,
Dan
Dec 02, 2008 | Technics Audio Players & Recorders
My cpu overheats and cuts off after i play a online game
try to unplug it for a while and put it back again, make sure you have a fan facing your computer.
Nov 09, 2008 | E-Machines eMachines Desktop PC
Sound problem
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Jan 13, 2008 | Denon AVR-1708 Receiver
Pioneer VSX-D307 Receiver Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
