Question about Ovens
Thermador sc301 I HAVE A TERMADOR SC301 OVEN AND THE CODE F 5 SHOWS WHEN TRYING TO USE IT. I TRIED TURNING OFF THE BREAKER BUT NOT RESOLVED. ANY ADVICE WELCOMED
  • 3,287 Answers
Read the info FROM Rick Ead at the bottom of this reply.
Posted on Apr 19, 2014
Powerman
  • 68 Answers
SOURCE: oven showing F2 fault
I concur with Catriver. F2 means that the oven temperature has exceeded a preset threshold. It could be for any of the following reasons: Welded relay contacts. Cooling fan stalled or blocked air flow to rear of unit. High resistance in oven sensor leads/high resistance in connectors especially at sensor in rear. There could be an open thermal switch in the yellow leads. The oven sensor would measure around 2650 ohms at the "clean temperature".
Posted on Apr 22, 2007
  • 1314 Answers
SOURCE: thermador oven secd272bs error code after install
check your owners manuel for code meaning and how to clear if its new call for service some can push stop reset or clear
Posted on Dec 31, 2007
  • 1314 Answers
SOURCE: Thermador Convection Oven
well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Jan 30, 2008
SOURCE: thermador oven display is dimming
replace the capacitors on the display unit. Just did this and it now works
theblog
Posted on Sep 19, 2009
SOURCE: I have a Thermador SC301 wall oven and the display
I have just repaired two SC301 ovens myself, but it is alot of work. You can get the oven's LED lights reconditioned at a company called CGI industries. Look them up on the web and click on the link for thermador. Removing the led panel and oven relay board is an involved job, but easier if you do it the correct way. First, turn off the power to the oven. Then pull the oven out of the wall socket about 1 quarter of the way. Remove the top cover of the oven with a phillips screw driver. This reveals the oven relay board. Take a digital picture of the board to remember the wire positions, or alternatively write them down. You also need to remove the touch panel (two screws underneath) and gain access to the LED. Remove the LED panel and wires. ship both to CGI (boards only) and you will have them back in less than a week. Costs about $170 before shipping. Reinstall and turn power on. All is good.
Posted on May 03, 2010
For Thermador SC301 ZC/01 built-in oven, should I buy 27 or 30 inch baking element?
You buy the one and only the one the manufacturer supplies for that model. Switching will cause problems with cooking and electronics in the immediate future. Order ONLY through a supplier that has the ability to look up the proper part for you.
Automatic Appliance Parts is one, 800.323.027, call them for the part and save yourself headaches.
Jan 26, 2015 | Thermador Ovens
Thermadore oven won't heat
Have you set the clock?
warmest regards
Richard The Repairman
Mar 27, 2014 | Thermador Ovens
I have a Thermador SC301 wall oven and the display has faded out. Thermador says I need to replace the whole control unit ($500 for the part!) Any cheaper fix?
Feb 08, 2010 | Thermador Ovens
Thermador oven display fc
Try turning off your circuit breaker for a few minutes. Then, after you reset it, push clear, then set your clock.
Sep 11, 2009 | Thermador SMW272 Electric Double Oven
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Dim LED on SC301 Thermador
local part whare house can sell you a "dim clock" kit for your machine i believe it contains a new display board as well new wire harness
Mar 14, 2009 | Thermador SC302T Electric Double Oven
F 34
My Name is Don from Mr Fix it Applaince in baytown texas. I have seen this F34 error as well and may have a solution for some of you... According to a Thermador error code book for a C301bs/03 single Thermador oven. It says its a air flow problem. This means it could be the fan motor sensor telling the controlboard that it is not spinning fast or not at all. or it could be a micro paddle switch that is activated by air flow, I found Two of them on the bottome of a double oven thermador a few moths ago.. Recap : if your fan blower motor has 4 wires going to it, it has a sensor reading the rotation of the motor.... if yours does not have this then you should look for a paddle switch.
Mar 10, 2008 | Thermador C301U Electric Single Oven
Oven turns off
call Thermador service center 800 735 4328
they said that if you have had an electrical outage or surge recently-
turn off dedicated circuit at circuit breaker for 1 HOUR
Feb 27, 2008 | Thermador C301U Electric Single Oven
Ovens Logo
77 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
