Question about Sony Alpha DSLR-A100 Digital Camera
Sony Alpha won't read memory card
Camera works fine without a card in it. But will not recognize or format any cards. Sony eHelp could not fix it. Says to mail camera in for repair at minimum of $228.
    Sergeant:
  • 321 Answers
Card slot pin is stuck or broken
Posted on Jun 19, 2009
When I turn on my camera it state unable to read memory card and gives you the choice to format. I have used the card and do not want to format it.
This is likely due to the memory card being damaged or it losing a part of data. The only solutions are either to purchase a new memory card, or to save the data from the memory card onto a computer or another location and then format it.
Oct 18, 2011 | Sony Alpha DSLR-A100 Digital Camera
Sony cybershot h3 camera error 13:01, memory stick not recognized by camera or computer, How can I recover my digital photos from the memory stick
I have succeed to recover photos from memory card with Tenorshare Data Recovery.It is a professional photo recovery software that can recover data after deeply scanning your memory card to look for lost data. By the way,you can download it and scan your memory card for free to preview whether your photos can be recovered.Get it from http://www.any-data-recovery.com/
Jul 17, 2011 | Cameras
Nikon D3100 cannot recognize an 8gb Sony memory card but can be read using the computer. it has been formatted in the computer already but still the camera cannot recognize it. Thanks!
The camera cannot recognize the card because IT HAS BEEN FORMATTED IN THE COMPUTER! Camera cards must be formatted in the camera.
Jun 27, 2011 | Cameras
My camera just suddenly won't read the memory card. I use an card reader in my PC, all was fine, down loaded photos off the card, put card back and bam! no card says the camera!! Help!!
Hi there, please remove the card & check it's locked or unlocked. If unlocked and you face the problem then scan the card by updated antivirus. If your card virus infected then camera can't read the card. So what you do now, format the card and then fix it back in the camera. And try to on . Hope you no face the problem then. Another reason if your card finish his life longer working capacity then error also come in camera display.
Thanks & waiting for your feedback.
Feb 15, 2010 | Sony Alpha DSLR-A200 Digital Camera
Will not recognize memory cards and can not format no pins bent, tried new cards
Hello Sir
# Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
# 2 Open up 'My Computer'. You should see it under the list of available drives.
# 3 Check its contents first to make sure that you have the right drive.
# 4 In 'My Computer', right-click on the drive and choose 'Format'.
# 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
# 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Dec 17, 2009 | Sony Alpha DSLR-A100 Digital Camera
What do i do when I turn on my sony alpha 100 and it tells me unable to use but I formatted it and it still says unable to use???
It's most likely a problem with the memory card. This message comes up when the card sustains damage to any degree. Did you lend your camera or card to anyone or put the card into the wrong reading drive by accident? It may be time for a new memory card/stick. Exchange it if it's still under warranty.
Jun 06, 2009 | Sony Alpha DSLR-A100 Digital Camera
When I inset my memory card into my camera it reads memory card requires formatting. What does this mean? used several memory cards they all say the memory needs formatting, i'm screwed
if you used already different kinds of memory and it has the same problem and no changes happen.
i think the probem is in your camera maybe you can bring your unit to a service center and try to ask them to reformat or reprogram it for you.
thanks,
May 30, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
I can't format any memory card (CF) with my Sony Alpha 100
you have a lock on your memory card check that !!
Jan 03, 2009 | Cameras
Camera won't recognize internal memory
copy all internal memory data on memory card and intialize camera by going in menu. after that try to format internal memory.
Jul 23, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
655 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
