Question about GE Spacemaker JVM1640SJ Microwave Oven
I have a GE spacesaver microwave, model number JVM1430BD002, that stopped heating. Everything else works, it just doesn't heat food. What would cause this?
Everything works, just doesn't heat food.
  • GE Master
  • 3,287 Answers
Sounds like a bad magnetron tube.
Posted on Apr 19, 2014
  • 43 Answers
SOURCE: GE Spacesaver over the range microwave oven
GE Microwave ovens, and Microwave Ovens produced by GE but released under different brand names, have had several power problems for the past 20 years. Because it is so easy to sell parts and charge outrageous rates for repair GE never corrected the problems. They just continued it in the next model. They found that you would most likely purchase a new unit rather than paying $75. for a service charge, and $150. for labor plus parts (if out of warranty period).
Most failures were cold solder connections on the power relay board. These would come completely dis-connected after arcing and burning away the solder. Could be 1 month, could be years, but they knew it would happen. This power relay board feeds 120volts to the LV (low voltage) side of the HV (high voltage) Transformer. No High Voltage,,No cook. Everything seems to run normal, but if you listen carefully you will not hear the low tone from the HV Transformer. Over my thirty years in the business I have re-soldered rather than replace so many I couldn't count.
Next to that, a defective Magnetron.
Posted on Jan 25, 2008
SOURCE: microwave will not heat food
I have the same problem and have figured out the following:
Most likely it is the magnetron - common problem for GE's. Replacement part list price is around $180 but you can find on ebay for about $80. Replacement is "doable" but tricky because the oven needs to be removed to replace the part. The GE replacement kit part # for magnetron and stirrer is WB27X10489. Expect a service tec to charge at least $200-$225 to make the repair so complete replacement of microwave might make more sense...unfortunately.
Posted on Dec 04, 2008
  • 3 Answers
SOURCE: GE Microwave doen't heat any food or liquids
PROBLEM MAY BE A RELAY ON THE CONTROL BOARD OR MAY BE A LOOSE WIRE FROM THE HV TRANSFORMER CKT.
Posted on Sep 07, 2007
  • 1214 Answers
SOURCE: Everything works except heat
Sounds like you've had a failure in the microwave portion of the unit.
Microwave not heating problems when the timer/controller board appears to function properly, are related to the following components -
1) Diode
2) Capacitor
3) Transformer
4) Magnetron
Posted on Jan 24, 2009
heatman101
  • 43501 Answers
SOURCE: My GE Profile microwave just stopped heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
45xs
Posted on Sep 30, 2010
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
Ge jvm1650wb005
one of the internal door switches, the high voltage circuitry or the circut board may have a problem to resolve this you need a qualified appliance technician
Jul 28, 2008 | GE JVM1650 1000 Watts Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
GE spacesaver II making loud noise and is not heating up food
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat food
chances are u have a bad transformer,scrap it
Mar 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave no longer heats; makes no sound or buzzing noise
hi..it sounds like a magnetron problem.It might have
got into damage.
check this out..
thank u..
kindly rate my response..
Jun 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JVM141G001 Spacesaver microwave; fan and heat not working
The average cost of a over the range microwave is around $550. You would have to call around or go visit an appliance store or a place like HOME DEPOT or LOWE'S to get a price quote on replacement parts. If it is cheaper, FIX IT. Good luck.
May 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Heat doesn't come on in microwave
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
May 01, 2009 | Microwave Ovens
Sep 06, 2007 | GE JVM1660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
382 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
