Question about Sewing Machines
How to make a fancy stitch
Im making a pineapple runner but how should i make a fancy stitch
  • Sewing Machines Master
  • 1,388 Answers
Try a sample of all the available stitches on your machine...then choose the one you like
You did not mention make/model
Posted on Apr 22, 2014
2 Suggested Answers
  • 980 Answers
SOURCE: I have an older New Home Sewing machine XR-V11
It does not matter what pattern you select, if you have the stitch width dial on 0 or set on straight stitch then that is all it will do, to do patterns you need a close stitch length about 2 or if it is not numbered get the stitches close to suit yourself and the stitch width on the widest number.
Posted on Mar 07, 2010
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
Kenmore 100 stitch 385 It will not pull the bobin thread up into the stitch. It does all the fancy patterns but the bobbin thread does not ingage in the stitch. Please help
Make sure that you have the bobbin threaded correctly, and that you have a tail of 3-4 inches held in your left hand until the top thread catches, make sure you move your handwheel towards you and your needle is inserted with the flat side facing the rear of your machinine.
Sep 10, 2010 | Kenmore Sewing Machines
I have an older New Home Sewing machine XR-V11 electronic I have figured out the threading, bobbin, regular stitching and back stitching. It has alot of fancy stitching on it I can get the dial to move to...
Mar 06, 2010 | New Home HF-2022
Using twin needle with Janome dc3050
you can just use the straight stitch.If you want to use a fancy stitch you have to be careful that the throw, as I call it is not too wide as you could break the needles and put the timing out. Also use a longer stitch than normal.Also use the stretch twin needle.
Jan 30, 2010 | Janome Sewing Machines
Brother ls2125 won't zigzag stitch
that sounds like a timing issue if it will pick up every now and then i would recommend taking it to a brother dealer for repair as timing is not easy to set
Jun 22, 2009 | White Sewing 915
I need to know how to find the basting stitch on my ex660
The basting stitch is not normally a separate stitch, just set the stitch length as long as it will go, and the same for the stitch spacing. Make sure you are not using any fancy setting or zigzag and this should be fine for basting.
Mar 14, 2009 | Sewing Machines
Can see alot of thread at the seam
Sounds like your needle threads are not tight enough.
Do some samples using different colored threads, if necessary, to see which needle thread is not doing the job. Then tighten in increments till you get the right tension settings.
It helps if you make notes of the correct settings on that material for the next time. Start a sample notebook, for the different materials you might use with tension settings for each, and if you do any fancy stuff with your serger, like pintucking, puffing, elastic application, ruffling and such.
Aug 12, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
