Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
How do I relace the drain flapper valve (528625P) on the bottom of the upper drawer in my Fisher Paykel 603?
I have worked on the bottom drawer and set it on the floor. Don't know if my spouse can hold the top drawer while I fiddle. Can anyone explain the valve replace process?
  • Ken R
    Ken R Apr 26, 2014
    Hi and Thanks! My note must have been bad - it is the top drawer that's leaking and need's the valve replaced. I thought the valve might be on the underneath side of the top drawer. I am looking for a way to replace the valve flap without removing the entire top drawer, and hoped it could be done in place from underneath. It looks, however, like the valve flap is on the rear of the tub and under the wiring cover. Do I understand that correctly?
  • Fisher and P... Master
  • 3,247 Answers
9.9.1 Remove the drawer front
9.9.2 With the tub opened release the tub clips and push back the
drawer rails.
9.9.3 Carefully release the four wiring cover clips from the front
lower section of the tub taking care not to damage them.
9.9.4 Release the three clips on the underside of the tub which
retain the wiring cover.
9.9.5 Pull the tub fully open and lift it up at the front (this makes it
easier to remove the wiring cover from the rear of the tub).
9.9.6 The wiring cover may now be carefully moved forward to
release it from the rear of the tub.
controller.
9.10.6 Unclip the drain hose cuff from the motor assembly taking care not to misplace the non-return flap valve so you know where it sits.
Replace flap valve and refit in reverse order.
Not sure why you need to take the top drawer out if you have already got the bottom drawer out and only need to replace the valve in bottom drawer.
Posted on Apr 19, 2014
  • Ken R
    Ken R Apr 19, 2014
    Sam, Thanks. This parallels wht I have in the service manual. I'm hoping someone who has done this could provide a shortcut. I need to replace the drain hose flapper valve on the bottom of the upper drawer, but was hoping to avoid removing the drawer if I could get to it from below when the drawer was open. Be nice if someone had a video!
  • Sam Apr 26, 2014
    Sorry about the confusion. If it is the top drawer then I see no reason why it cannot be done without taking the drawer out from the housing. I have not done it but it will feel like working under the chassis of a car lying down with face up. I might suggest it would be easier if you can lift the dishwasher on to a work table and sit yourself at eye level. Make sure the dishwasher is fastened to table with rope or strap so that it does not topple when you pull the top drawer. Good luck.
  • 11 Answers
SOURCE: fisher & paykel 2 drawer unit
yes there is. It is just inside the white hoses that drain the system. 1 per drawer. They cost about $0.50 but are a real pain to get to. This flap will go bad in about 3-5 years and maybe sooner depending on the temp of the water used.
If the bottom flap goes bad, using the top drawer will drain into the bottom drawer.
Posted on Jan 14, 2009
Master_Tech
  • 770 Answers
SOURCE: fisher paykel
Check your email
Posted on Jul 09, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel DD603 top drawer will not drain
Hi and welcome.
Either your hubby forgot to knock the plug out of the dishwasher connection on the new disposal, or he does not have a dual-air gap installed and the hoses to the dishdrawers do not have a high loop to prevent back-siphoning into the drawer...
Posted on Jan 07, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
SOURCE: FISHER & PAYKEL DD-603
I have a DD603 bought used, put in the upgrade kit. But now it goes into pause several times during a load. It happens on both drawers very very anoying.
Posted on Mar 30, 2010
Fisher paykel dishdrawer bottom drawer washes fine leaves water in top drawer
At some point the two drawers individual drain hoses are joined using a "Y' type connector. Check this, and everything beyond this point for restrictions or blockage. It sounds like the bottom drawer is pumping its drain water out normally, but some of that water is backing up to the upper drawer. This is an installation or plumbing problem that is external of the dishdrawers.
Jul 25, 2016 | Fisher and Paykel 23 in. DD-603SS Built-in...
DD-603 cycle and draining problems.
check your kitchen drain as it might be blocked or if you have a garbage disposal (kitchen insinkerator) make sure it is cleared before running the dishwasher.
Jul 18, 2012 | Fisher and Paykel 23 in. DD-603SS Built-in...
How does one access the float switch in a fisher Paykel bottom drawer dishwasher
The flood switch is at the base of the dishwasher. You will need to take the bottom drawer out.
Download the installation manual to find out how to take the drawer out.
Make sure the mains power is disconnected.
Hope this helps.
Oct 19, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Fill fault on top tub and bottom works fine. getting about 30 ounces of water and it takes about 3 minutes for fault code to come up
If your bottom drawer works fine then your inlet water valve below the bottom drawer is bad. Click on the link below to see how to repair this dishwasher.
Appliance Repair Video
Mar 26, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Top Drawer Beeps all the time. Will work if patient. Bottom drawer OK.
I am assuming only the bottom drawer works and not the top.
Are you able to note down which LEDS on the top drawer door inside top are on?
Sep 19, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Water backs up into upper drawer when lower draw is run
make sure hoses arent blocked from bottom drawer. if they not blocked change the check valve in the hose. its under the dishwasher drawer pull the drain hose off the drawer. a small rubber check valve is there
Feb 07, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Dec 12, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
F2 Fisher Paykel 603 issue
You can download the service manual from
http://www.fisherpaykelparts.net/index.php?categoryid=115&productid=18 at a cost of $20
But if you can go through the user guide which is free from
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
you should be able to work out how to remove the impeller and rotor once you have taken out the filter plate. It needs a slight twist and pull at the same time. It is likely there is some debris between the drain filter and the rotor cavity. You may need to insert a thin stiff wire through the drain filter sump.
Oct 27, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
E-mail for Fisher Paykel DD603 manual
Josh, you will need to have a Tech out to look at it... F/P will not sell you parts to repair it. The F1 indicates that the flood switch has been tripped. There are many possible causes for this but probably the upper drawer link support has broken and is getting stuck between the lid and the drawer in which case you will need a new lid and link support.
May 05, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
199 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
