Question about Kenmore Dishwashers
Kenmore Dishwasher completes main wash cycle, drains but will not refill when rinse cycle begines
Starts, fills and completes main wash cycle. When thr rinse cycle begins, no power gets to the water solenoid valve, so doesn't refill. Circulating pump continues to run indefinitely. The main control board was replaced, as well as the soil/temperature sensor, but problem still persists.
  • GriffinJim Apr 19, 2014
    Model 66513793K600
    New Friend:
  • 56 Answers
What model number is your dishwasher?
Posted on Apr 19, 2014
  • 4 more comments
  • Ken Johnston
    Ken Johnston Apr 19, 2014
    on the back of the water inlet is a power pin connector.
  • Ken Johnston
    Add a CommentI would be sure that it is securely in place and then see if the power is getting thru.
  • Ken Johnston
    test the call for power with a power sensor that you can get from a local hardware store or online.
    Have checked the pin connector, as well as the wire continuity all the way back to the pins on the main control board. Power is reaching the solenoid during the first fill upon start since that works fine, but not during the rinse cycles. That would generally indicate an issue in the main control board, but that was the first thing we replaced. Also replaced the sensor (soil and temp) with no change in results. Have measured the water temp coming into the dishwasher and it is over 120F.
    It would appear that there is some other condition causing the control board to not send power to the solenoid during the rinse cycle. Have also checked the float water level switch and that is working fine. Have also verified the continuity of the ribbon connecting the main control board to the control panel board, and it checks out OK. Also reset all of the connectors located in the door circuitry. Any other areas that you m ight direct my focus...? Thanks again for your help...!
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
  • 423 Answers
SOURCE: LG LDF6810 Dishwasher Starts filling with water then pumps water
Because you are not getting an error message, I agree that the controller card is malfunctioning. Almost everthing else would triger an error.
Recommend replacing the controller card.
Posted on Mar 30, 2009
SOURCE: frigidaire fdb1050rem2 dishwasher will not drain during was cycle
Checked water temperature at water heater. It was at 110 degrees. Turned water heater up to 125 degrees. Dishwasher works perfectly now.
Posted on Mar 31, 2009
  • 11 Answers
SOURCE: Item: Whirlpool Ultra Dishwasher Age: 3 yrs
Larry,
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Posted on Oct 30, 2009
  • 401 Answers
SOURCE: My Quiet Partner III dish washer gets very noisy
yes its a bad inlet valve. sometimes you can turn down the house valve the washer is connected to a little to stop the noise.othe then that replace the inlet valve.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Posted on Feb 27, 2010
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not drying
Perhaps your control knob is misaligned?
Dec 17, 2017 | Smeg 18 in. DWF409WH Slim-Line...
No water during any cycle.
if no water is coming in how is it agitating?is it filling at the beginning,then it starts to wash the clothes,now does it drain and then it won't fill again,send the model number and more info,
Jul 02, 2010 | Kenmore 24032\24036 Top Load Washer
Our dishes have white film on them. 5 repairmen have said they have no idea to the cause. We have tried everything vinegar, rinse aids etc. Could it be a pressure problem due to a plumbing default in...
on an empty cycle fill the machine and use some C.L.R or other lime and scale remover in the machine and let it wash through the cycle.
try putting more water in the tub once the fill cylcle has completed and the wash cycle starts.Make sure the incoming water temp is at least 120 degrees.
if there is no change in the washing of the dishes
you may need to replace the main wash pump. if there is a change then you need to replace the fill valve or increase the water pressure to allow more water in the unit during the fill cycle
May 18, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Hotpoint washer fills begins to agitate then refills continously.
Very likely your drain hose is set too low. You can solve this with a standpipe or a kit called a siphon break.
Dec 31, 2008 | Hotpoint VBSR3100GWW Top Load Washer
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwashers Logo
175 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
