Question about Sanyo DP26648 LCD TV
Unit turns off after 3 to 5 seconds
I turn on the TV, the light comes on, the source pops up saying PC, which is what I had the source on to begin with and then turns completely off after 3 to 5 seconds. In that time I can turn on the menu but it shuts down right after the menu pops up.... Can anyone tell me which capacitor needs to be replaced?
    President:
  • Sanyo Master
  • 749 Answers
This does not sound like a capacitor problem.
Bad capacitors usually cause the TV to have a SLOW startup, not so much to shut off after they are once started. Of course both are possible, but the former is a whole lot more common (based on my experience).
Also, bad capacitors are usually easy to spot even with a naked eye. Just look at your power supply board and see if there are any that are bulging.
Not seeing any is not a guarantee, but more often than not is sufficient to rule that out as a possibility.
Finally, here are some repair and replacement alternatives for DP26648 power supply issues:
http://www.coppelltvrepair.com/search?q=DP26648
Posted on May 08, 2014
4 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: Green power light comes on, the turns right back off. No picture. Please help
I'm not sure what TV model you have. But, thing I can tell you is the most common problem.
Most of the time with flat panel TVs, the power supply for the screen fails. And the TV normally turns itself off to protect other parts in the TV from being damaged. Basically " Protection Mode".
You can try leaving the TV unplugged for 30 minutes so the TV can reset itself; then try again turning it on. If it doesn't work after that, it's time for the TV repair shop.
Posted on May 21, 2009
  • 12 Answers
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Posted on Dec 16, 2009
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
  • 608 Answers
SOURCE: when i turn on the tv , it shuts itself off in 2
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
My tv come on and turns off stays on 3 min.
How old is your tv and when was the lamp changed last? If its more than two years then you need to change the lamp. Its easy DIY. Buy lamp from reliable source or a known shop. check out rate for lamps on www.fixurtvs.com. thanks if you voted.
Apr 12, 2010 | Samsung HC-R5245W 52" HDTV
Magellan RoadMate won't compute if connected to power
unplug the charger, then turn the 1200 on, once its fully booted, hold the power button for 15 seconds..the screen will go blank after a few seconds, but continue to hold it for 15 seconds.
now, with the charger plugged in and unit off, press and hold the power button for upto 7 seconds or till it starts.
if that fails, let me know and i can tell you something else to do.
bill
Jan 23, 2010 | Magellan Roadmate 1200 Car GPS Receiver
We have a Philips 4 BDS4231R/00 and it does not start. We can here the relay sound and if we turn it on and off say 7 - 10 times it works fine. Could anybody tell me how this can be fixed. Please
Hey John, I am experiencing a very similar problem. If I unplug the TV when it is on (green light) and plug it back in. It begins green, and clicks to red. I immediately turn the TV back on with the remote. Most of the time it seems to struggle for several seconds, sometimes with a little scratchy audio popping in and out. It will then go from green to red on the TV and if I try to turn it back on it will go green for a few seconds and back to red but without any click coming from the TV. No matter how many times I try after that, no TV. If, on the other hand, I unplug while green, plug it back in and with the remote turn it back on after it has come up green and then clicked to red, it will come on. It might take thee or five times but at least it comes on... If you hear of a real solution, please let me know (bennettkw@hotmail.com) in the meantime, best of luck.
Dec 28, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Don't know how to turn off the alarm. Bought this used (made in 1995) so there were no books with it. It comes on every day at 2. The system is on 'standby' all the time. I just don't seem to find the...
Setting the ON time (Example: AM 10:15).
1. Press the TIMER button on the Unit for more than
two seconds.
The Timer indicator lights up and the hour digit of the
current ON time blinks on the display.
• When the clock is not set, “CLOCK” and “ADJUST”
appear alternately on the display. Set the clock first.
Press the ¢ or 4 button on the Unit to set the
hour you want the Unit to come on.
Pressing the ¢ button moves the time forwards and
pressing the 4 button moves it backwards. Hold
down the button to move the time rapidly.
2. Press the TIMER button.
The minute digits of the ON time blink on the display.
Set the minute you want the Unit to come on, using
the ¢ or 4 button.
2 Setting the OFF time (Example: PM 1:30).
1. Press the TIMER button.
The hour digit of the OFF time blinks on the display.
(The same time as the ON time will be automatically
set.)
Set the hour you want the Unit to be turned off, using
the ¢ or 4 button.
The minute digits of the OFF time blink on the display
Set the minute you want the Unit to be turned off, using
the ¢ and 4 buttons.
3 Selecting the music source.
The “TUNER” or “CD” blinks on the display.
2. Press the ¢ or 4 button to select the music
source you want to listen to.
The display changes as shown below.
TUNERôCDô(back to the beginning)
4 Setting the volume level.
The current volume setting blinks on the display.
2. Press the ¢ or 4 button to select the volume level.
-- :The current volume level will be used.
0 to 50 :When the timer is turned on, the Volume
will be automatically set to the selected
level.
5 Press the TIMER button.
The timer setting is completed and the display returns to
the display before you set the Timer. The Timer indicator
remains lit.
6 Before turning off the System, prepare
the music source selected in step 3.
TUNER: Tune in to the desired station.
CD: Insert a CD. (Playback will start from the first
track at Timer on.)
7 Press the % button to turn off the System.
In standby mode, you can see the Timer indicator ( )
on the display.
• When the timer turns on, the Timer indicator starts
blinking and the prepared source in step 6 will be
played.
To cancel the timer, press the TIMER button. The
Timer indicator ( ) goes out on the display.
To re-activate the cancelled timer, press the TIMER
button to light the Timer indicator ( ).
At this time, you can see the current timer settings. Each
setting appears on the display for two seconds in the order
of ON time, OFF time, music source and volume.
To change the timer setting, repeat the setting procedure
from the beginning.
Oct 31, 2009 | JVC KD-G210 CD Player
TV will turn on for 2-3 seconds and then turn off
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least! Mahalo!
Mar 12, 2009 | LG 50PC3D 50 in. Plasma Television
Power problem
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Jan 30, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
Unit turns off after 3 seconds
sir i think theres something wrong with the power supply kindly check it out thanks and hope too help you,,,gud luck
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
TV tries to come on 3 times
The load pop was something blowing in the unit. I would take the tv to a repair center. http://direct.where2getit.com/cwc/apps/w2gi.php?client=rcathomson&template=searchretail_new
Jun 09, 2007 | RCA D52W19 52" Rear Projection Television
Sanyo DP26648 LCD TV Logo
79 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
