Need to know when my order is comming
And also when my paint gun filters are comming
Request tracking Id's and the name of the delivery company.
always pay with PayPal so you are protected.
and log a disput if you get no response from seller.
Posted on Apr 22, 2014
My spray gun keeps stopping and then I reverse tip and it works then stops then I reverse tip and leaking
It's probably the paint-I had a problem with certain brands. I started putting a cheesecloth type filter around the uptake to help filter larger particles and it works a lot better.
Jan 31, 2015 | Air Tools & Compressors
Iwata eclipse G6 airbrush gun - no paint flow, bubbles forming in gravity feed bottle.
it is rather large (usually 0.6mm nozzle) airbrushing gun,
symptom indicate that needle is closing the nozzle and not retracting, gun need cleaning! or adjustment - seem like both...
remove paint from the feeder, remove feeder bottle from the gun body, clean it well with paint stripper and then solvent/water allow it to dry
remove front casing from the gun and check for any physical debris around the needle or in the chamber, carefully clean without damaging the needle. needle is stainless should be nearly mirror finish.wash with solvent and use toothbrush - DO NOT USE METAL BRUSH!
put it back together and check if it works correctly, if you have any flow from the front - fill about 1/3 of the tank with paint stripper and then spray it to the sink or whatever other safe place. do not forget to wear safety mask, goggles and gloves! paint stripper will eat through your skin! if you splash yourself, have few spoon of vinegar mixed with 2pints (1 liter) of water and this solution will deactivate paint stripper! SAFETY FIRST!
if gun still do not work - you need to strip needle assembly and clean it correctly, put your gun on the table on butcher paper, remove screw holding needle on the back (watch for the spring!) put whole assembly on the paper in the order in which you removed it,
clean needle and needle seat, lightly grease it with vaseline and in reverse order put it back together.
regulations:
very bottom screw - this close to the airhose, it regulates volume of the air to the gun, you very rarely need to adjust that one, you increase volume with haevy paint and decrease it with light paints
needle screw - it regulates volume of the paint itself, closing it clockwise will decrease amount of paint, anticlockwise will increase volume of paint
top screw - it regulates the spray pattern, totally closed - round pattern as there will be no flow to side vents, more open, more flat the spray pattern,
i would suggest fill the bottle with water and put some butchers paper on the wall and experiment what is what and what pattern is most suitable for your use.
hope this little info will help you solve your problem, it is good you give the model, it will be better if you provide as well what medium you use, was it acrylic, oil, water based? all of them behave little bit differently in airgun...
please do not hesitate to leave your opinion and points... thanx!
Oct 04, 2013 | Air Tools & Compressors
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
Airless sprayer, paint comes out like silly string
In order of ease/cost to fix: First, check your spray tip. Most of them are reversible to help spray out any debris that may be lodged in them. Next, check that all of your filters are clear and let paint flow freely. Depending on your model there are up to three, one filter in the spray gun, usually in the handle, another filter is at the pickup tube and some sprayers also have another filter on the machine where the hose hooks up. Another cause may be because your paint is way too thick or not mixed well. A highly recommended paint additive for airless sprayers is Floetrol, it makes the paint flow extremely well. If none of these fix your problem you may well have a worn packing or diaphragm, again depending on your model, and the machine isn't developing enough pressure to atomize the paint. If you have the means put a pressure guage in line with the hose at the machine and turn it on. You need at least 1200 to 1800 psi for most latex paints, a little higher for enamels and thicker paints.
Dec 17, 2010 | Campbell Hausfeld Air Tools & Compressors
Why does my gun keep spitting
Spitting is usually caused by not filtering the paint through a strainer (made for the purpose by the paint manufacturer). The paint debris blocks the paint for just a moment, then spits it out. Easy fix!
Jun 09, 2010 | Wagner GX10 Airless Spray Gun
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
Wagner Paint crew - No pressure
In order of likelyhood:
1. There is an inlet valve where the paint first enters from the hopper. With the machine off, you can poke your finger all the way down the hole. It's spring loaded and will depress abouta quarter inch. If the inlet valve is stuck no paint will pump in PRIME or SPRAY position.
2. In SPRAY position. Motor runs for a few seconds then turns off. This means the pump is working. When you pull the trigger, if you get poor pressure, the problem is in the gun. Unscrew the handle and remove the filter. Clean out everything you can, and replace filter if necessary. Also try turning the spray nozzle 180 degrees and spray to clear if necessary.
there are more things that can go wrong, but these are the most likely.
Jul 08, 2009 | Air Tools & Compressors
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
