Question about GE J2S968SHSS Dual Fuel (Electric and Gas) Kitchen Range
Oven heat temp.. small ven only heats from the bottom, oven only has 2 settings..urgently neen to know how hot is hi, and how cool is low..plwase?????
Oven only lights from the bottom and has 2 settings, need to know how hot is hi and how hot is lo ..
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 117 Answers
Get yourself an oven thermometer they are available for a few dollars at most homeware places, put in in the oven and you will be able to get your temperatures easily.
Posted on May 08, 2014
Turbo chef is not heating up, coming up on it reads, f8 low heat
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Jul 03, 2010 | TurboChef C3 Single Oven
Oven not heating properly
you sure you have 240volts at the unit??? chk for 120+120 volts to get 240volts,one leg out and you'll have little to no heat condition
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
After temp is set bottom oven will not heat up to desired temp
you probably have a burnt out or shorted out lower bake element in you r lower oven. it sometimes will actually break apart or look like it sparked thru the black tubular section. it is common and will cause no heat during the bake cycle.
you could try to do a broil and see if it gets hot and that would let you know the control is ok and just needs the lower bake element.
Jan 28, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I have a 05 Nissan Sentra and it keeps running hot and the heat isn't blowing hot. But when Im under the hood the hoses runing from the radiator and thermastat; the top hose gets really hot while the...
Hey iisha, although obvious, 1st thing to check is the coolant level. If it's low, the engine will run hot and the low level prevents coolant from circulating to the heater core inside the car, so the result is little or no heat, but engine running hot situation. The top rad. hose takes hot coolant from the engine, it flows down thru the radiator where it is cooled (w/ help from the fan) and the coolant returns to the engine at a reduced temp. to keep the temp under control, and it's returned thru the bottom hose (the result is the bottom hose should be cooler thant the top. There's more involved than that, so 1st check your coolant level, if it's ok let me know I'll help further. Hopefully the fix is that simple, and it is a rather common problem.
Dec 08, 2008 | Nissan Sentra Cars & Trucks
Bake will not heat up to where it should
If the oven is getting warm but not as hot as it should your thermostat is bad. They are a small pain to replace but can be done if you don't mind removing the front panel and removing 2 small screws. It would be best to get your model number and remove the thermostat to get exactly the same one. Let me know how it turns out. Ken
Dec 02, 2008 | Whirlpool Ovens
Bosch hbn s gb
oven element would need model and ENR No. to supply
Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Bosch HBN 642 -- single oven cycles and doesn't get above 325
    WHAT WAS HAPPENING AT 1ST YOUR HI-LIMIT TERMAL SAFETY OR OVEN TEMP SENSOR FELT THAT THE OVEN WAS GET TOO HOT AND SEIZING OPERATION UNTIL SAFE TEMP WERE OBTAINED THIS IS GENERALLY A FAULTY OVEN TEMP SENSOR. I WOULD ADVISE YOU TO CONTACT A CERTIFIED TECH TO LOOK AT IT AND P.S. DON'T MENTION THAT YOU TOOK THE MACHINE APART MOST SERVICE COMPANIES WILL NOT SERVICE THE MACHINE IF IT BEEN TAMPER WITH BY THE CUSTOMER DUE TO INSURANCE AND LIABILITIES
    May 28, 2008 | Ovens
    Oven doesn't heat
    sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
    Mar 26, 2008 | Kitchen Ranges
    GE J2S968SHSS Dual Fuel (Electric and Gas) Kitchen Range Logo
    43 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
