Question about Amana NED7200TW Electric Dryer
Amanda dryer 7200 series error code E5 code?
27" front loader...looks like E (top horizontal line is out) 5 error code. Cannot find anything in the orders manual. Help!
    New Friend:
  • 19 Answers
The E5 error code is only referenced by a technician. More than likely it refers to a circuit board problem. Only solution is to have it replaced by a technician.
Posted on Apr 19, 2014
My Amanda front loader is saying f5 e3
There is an issue from the lid lock. Remove anything from the top of the washer. Press power to end any cycle. Wait for the washer to drain if needed. When the washer has drained, unplug the power to the washer. Wait for 2 minutes and then plug the power for the washer back in. This process will correct the issue with the lid lock. If this doesn't work, please call for assistance at 866-616-2644
Apr 08, 2018 | Washing Machines
How do I remove the face plate of the dryer
what make amd model dryer? as a general rule first UNPLUG the dryer, if it is gas turn off the gas supply then you have to remove the dryer door first for front loaders. Once that door is off look for any additional screw that were hidden, there may or may not be any. Then look for any brackets that may be attached to the top panel of the dryer. If it is a top loader skip that, then you pry the top of the dryer up they are usually held down by clips. Then grab/pry the front of the dryer off. Those panels are held on by clips also but take a look for any brackets that might have screws in them. It should all be visible.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_32f4b76dad4781c4
Dec 17, 2014 | Dryers
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
Apr 30, 2014 | LG WM3431 Front Load Washer / Dryer
How to take apart a whirlpool gas dryer
If the dryer is a front loader and if a top filter in filter it has two screw take them out and in front where top and front put a screw driver and pot the top up. When top came up on the side at top they are 5/16 screws take them out some of the front just slides up and off but if it has a full front door open door and on ea. side they are three screw take the top screw on top of the three screw out and slides door off and unhook wire on door switch on top of door. Look under drum and see how belt go on pulley so when you go to put it back on you will know how to. Take belt off pulley and drum and pick up on drum and pull it out and there is motor and gas heater and roller in back of wall now you have it apart.
Apr 29, 2014 | Dryers
Kenmire 80 series dryer drum doesn't turn
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 05, 2012 | Kenmore Dryers
How do I open the drum area of Kenmore model #66712694 dryer to clean it?
First you need to determine if your dryers blower housing and other components are located in the rear of the dryer or underneath the dryer. The quickest and most simple way to do this is to look at the front of the dryer and see if it is one complete front or two pieces. There will be a small gap completly across the front about a quarter way up if its two. If its two pieces then your work is going to be up front. You remove the lower kickplate with a flat screw driver and pressing the clips, one on each side in the groove. If its a solid front then you'll need a 1/4 " driver or drill with 1/4" socket, adapter, etc. From the rear of the dryer, there are about nine 1/4 inch screws you take off to access the area your looking for. Hope this helps, good luck. Now to look around the drum area, it also depends on if its one or two pieces. If one, remove the lint trap and take the two phillips head screws then take a flat head and pop the top up. Then inside, top front left and right sides there are two screws, either 5/16" or 1/4" screws you need to remove to pull the front off. If two pieces you'll have to pop the top as earlier, but you'll have to remove the kickplate, then two additional screws at the lower portion of the top piece as well as the top.
Apr 26, 2012 | Kenmore 65924 Electric Dryer
What is a ld error code? It will not spin when it is supposed to spin fast. This is the error code that comes up.
LD is the error when it takes longer than 5 minutes to drain the water out and reset the sensor. Press pause/cancel twice to clear. The washer will begin a slow spin, and when the motor allows, increase the spin speed towards the spin speed selected. Depending on the model, it will make several attempts, each time pulling water off of the load at the slower speed. If it cannot "get permission" to increase to it's selected speed within the allotted tome, it ends the cycle and the error code "LD" is displayed. Usually two common things can contribute to the DL alarm. One is the strainer, and the other is the drain line. The strainer is in line between the drum and the pump. On a front loader, it is behind the kick panel below the front main panel. It is connected to the drum with a rubber hose and strains the water going to the pump. Clean the strainer, and, while it is open, look inti the pump cavity. Remove any debris that you find there. Reassemble the strainer.
Anything that gets by the strainer and pump will eventually pass through the drain line and on out through the house drain. Empty the drain hose into a bucket to help displace any sediment and debris in the line. If possible, run an empty cycle with the drain hose pointed outside.
Best regards, --W/D--
Aug 13, 2009 | Kenmore Washing Machines
Error code 7
The error code 7 is in fact a motor error.
The motor that drives the spin cycle has become faulty. The only solution now is to get an engineer in to fix it or get it sent away to get repaired.
Sep 08, 2008 | Haier XQG50-11 Front Load Washer / Dryer
Amana NED7200TW Electric Dryer Logo
611 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
