Question about Bose 161 Rear Speaker
Bose 161 bracket screws. where can I find them cause I couldn't find them in the box
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Call supplier.
Posted on Apr 19, 2014
What are the Bose 161 wall mount bracket dimmensions?
Here's a link,just get your tape measure out and measure the dimensions on the picture Fabin,I have Bose hooked up to my Laptop,they sound so Awesome.... http://www.frontrowelectronics.com/productimages/og_161.pdf
Jun 21, 2017 | Bose Televison & Video
How to open a BOSE 161?
Yes, the grill can be removed. To pull out the grill you need to clamp on the sides but inside between the outside of the mesh and the outside part of the main plastic housing. pry at least a one incu on both sides, clamp it and wiggle it up until it pulls out. to reomve the speak is more work, on the center of each side, you will want to use a 1/4" screwdriver, but nice and thick. slide it on the center of one fo the sides of the speaker downward. looking downward on it, you will see two dimples with the center opened. slide the screwdriver between the dimples at least 1/4" down and thenbend outward slightlight the scredriver so it can grab on to the opening underneath the dimples., keep doing this on all four sides until it is loose enough for you to wiggle it our by hand. do note, that the wires inside are real short, to remove the speakers completely you will need to unwind the wiring attached. the wire is solid not mesh, so you will need to use a tweezer of sort or micro screwdriver(such as for glasses) to loosen the wires. once that is done, you can pull out the speakers a swell as other components. remember, the wires inside are real short. not long enough to disconnect them, a little work is needed to disconnect the wires.
Jun 15, 2012 | Bose 161 Rear Speaker
Need to purchase valves & brackets for this.....only have the ceramic fixture.
You will probably have to go to a plumbing wholesale house to find the hanger brackets. If they don't have eljer bracket they should have universal brackets that will work fine. They would probable be your best bet for the flush valves also. Thank you.
Aug 29, 2011 | Eljer 161-1150-00 White Dover Wall Mount...
Ahoj, I have just switched my acer laptop on and a "pop up" has appeared saying Práve som prešiel môj Acer laptop na a "pop...
remove your acer power management application from the save mode maybe it crash with your software and reinstall the software
Jan 16, 2011 | Acer Computers & Internet
I have four Bose 161 speakers and an Acoutismass 5 bass unit (original cubes are bad and replaced with the 161s). My Onkyo receiver started turning off and going into protect mode recently. Bought new...
you're going to need a ohm meter (good electrical testers have them) and make sure ohm ratings from speakers match the ratings for your receivers. Sounds like to much resistance for receiver(s)
Jan 06, 2011 | Bose 161 Rear Speaker
Auxiliary audio input for 2008 Mazda MX-5 with Bose sound system
Yes you can add auxiliary or ipod interface also xm radio
go here for more information
http://www.oemautosound.com/c-161-mazda-products.aspx
Jun 30, 2009 | 2008 Mazda Mx 5 Miata
Scanner reads code (060)
Location of "ECM" is Under the Air Filter Box
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner box, refer to the air cleaner box.
  3. Remove the gray and black connector from the PCM.
    1. Remove the harness clip bracket from PCM bracket.
    2. Remove the nut from the upper bracket mount.
    3. Raise vehicle and support on hoist.
    4. Remove 2 lower bracket bolts.
      1. Remove 4 screws from bracket and remove bracket from PCM.
      INSTALLATION
      1. Install bracket to PCM and tighten screws.
      2. Install PCM and bracket to body and tighten the 2 lower bolts.
      3. Lower vehicle.
      4. Install upper bracket nut and tighten.
      5. Clip in wiring harness bracket.
      6. Install gray and black connectors to the PCM.
      7. Install the air cleaner box, refer to the air cleaner box.
      8. Connect the negative battery cable.
Mar 14, 2009 | 2001 Dodge Neon
Bose lifestyle 25 system and Panasonic Plasma Tv not working together
I posted the message as Tet Tet before. I can now tell you that I have resolved the problem. The issue is with the Panasonic 50Inch TV. Some people reported the same problem but only when the TV was up on the wall. It turns out that the problem lies with the metal discs which screw on at the back of the TV to enable you to hand the TV on the wall bracket. In my case I had excessive interference caused at the back of the TV (could be the fan). When I put the TV on the wall bracket the metal discs would be in contact with the wall bracket which in turn was acting as an antenna causing the iterference to the bose remote which operates at a frequency of 27.45MHz. You can solve the issue by adding some insulating tape around all the metal discs avoiding them to make contact with the wall bracket. If that fails Panasonic will swap your TV for another one like they did with me. I can now enjoy my Bose System with the 50 inch Panasonic TV. It took me three months but managed to get a solution. I hope this helps. For further info you can mail me at rizzocarlo@hotmail.com. These discs should be made of metal because they are perforating the metal screen at the back of the TV. Panasonic please change this design.
Dec 06, 2007 | Televison & Video
Bose 161 Rear Speaker Logo
202 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
