Question about RCA TruFlat 27F520T 27" TV
Tv rca 27f524t flashea led no turn - RCA TruFlat 27F520T 27" TV
    Top Expert:
  • RCA Master
  • 75,571 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Apr 19, 2014
My RCA HD LED 32 IN TV WON'T TURN ON
Power supply board has a problem. Parts can be has online at shopjimmy web page
Oct 20, 2014 | RCA L32HD31 32 in. LCD HDTV
White horizontal lines on top of screen
Replace all the electrolytic capacitors in the vertical output section circuit. There will be 5 or 6 of them. Replace the at one time. The fault you see is technically called " vertical retrace lies".
Apr 28, 2012 | RCA 27F524T 27 inch TV
Need password for rca tv model 27f524t
If you forget your password, you can reset it. Make sure the TV is off.
Press VOL- on the TV's front panel and then CLEAR on the remote for
approximately 5 seconds. The TV will turn on. Enter a new password
the next time you access the PARENTAL CONTROL menu or the TIME
menu.
Nov 26, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
I need an owners manual for a model 27F524T TV bought in 2008
You can download the required manual from:
http://tv.rca.com/RCATV/RL/32V524T_167216302_IB.pdf
(To download and save the manual to your computer, right-click on the above link, select Save Target as and then click Save)
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Dec 17, 2009 | RCA Televison & Video
Need code for Innovage jumbo universal remote for a rca tv
The Innovage Jumbo users manual lists over two dozen RCA TV remote codes. They are:
000, 003, 004, 005, 007, 009, 011, 015, 048, 082, 092, 094, 096, 098, 101, 102, 103, 107, 113, 125, 129, 167, 179, 187, 188, 191, & 194.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
If you can't be bothered to enter each of those codes one at a time, you might consider the auto-search function.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Sep 17, 2009 | RCA TruFlat 27F520T 27" TV
Need rca univeral remote code for a toshiba tv
1. Manually turn on the component you want the remote
to control.
2. Press and hold the component key (TV, DVD•VCR, AUX, SAT•CBL) you wish to program. The LED INDICATOR turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the LED INDICATOR blinks four times, and the process is exited.
3. While holding down the component key, enter the four-digit code. While you are pressing the numbers, the LED INDICATOR turns off.
4. After the fourth number is entered, the LED INDICATOR turns on. At this time, release the component key. If the LED INDICATOR turns off, you have entered a valid code and have followed the correct procedure for Direct Code Entry.
If the LED INDICATOR blinks four times when the component key is released, This means that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 2.
RCA Toshiba 3 digit codes. 000,018,021,023,048,049,071,072,073,085,...
RCA Toshiba 4 digit codes.1000,1048,1072,1105, 1109, 1118,1160,1190,1241 Good Luck
Jun 14, 2009 | Televison & Video
RCA 27F524T Power comes on But no Picture
i want to know who wants to sell me their rca t.v?
Jan 21, 2009 | RCA 27F534T TV
CURSED RCA
its the EPROM chip and it is happening in thier other models as well. If you leave it unplugged for about a couple of weeks it will work for a while but will start again and it will get worse
Sep 26, 2008 | RCA TruFlat 27F520T 27" TV
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
