Question about Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range
Turned oven to 350 degress but it wont go past 200 degress please help
    Habit-Forming:
  • 119 Answers
Ben, the most common failure for this range is the oven temp sensor. Part # 316490001. Sensor is accessible from the back of the range. turn off power, remove the sensor and check the resistance of the sensor you have now in a glass of ice water (12 oz) mixed with one tablespoon full of salt, well dissolved. you should read approx 1000 ohms +/- 4.0 If you are outside of this value, replace the sensor.
Posted on Apr 21, 2014
Oven temp can be reduced but not increased
Bake at 350 degrees? Oven temperature is uncontrollable ...
www.slate.com/.../bake_at_350_degrees_oven_temperature_is_unc...
SlateAug 8, 2012 - Your oven may say 350 degress, but can it be trusted? ... over their hot boxes, but the dials still typically only offered low, medium, and high settings. ... It's not particularly surprising that this development came when it did.
Why You Should Stop Worrying About Your Oven ...
www.thekitchn.com/why-you-should-st...
Apartment Therapy's The KitchnAug 14, 2012 - If you fret over the accuracy of your oven's internal temperaturereading, you're working too hard. ... If that all sounds like cause for worry, it's not, and here's why: the ... low (under 275 degrees); moderate (between 275 and 350); high ....It's certainly possible to cook without temperatures, but one will have ...
temperature - Glass Dish Baking Temparature - Seasoned ...
Dec 14, 2015 | Cars & Trucks
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
My oven wont shut off and gets very hot way past set temp what up with this.
Good Morning Friend,
I understand that your Frigidaire electric oven, model# es 200/300, will not shut off. I also see that it gets very hot, way past the set temperature. First, make sure you have not put it into the self-cleaning cycle. If it is not in the self-cleaning cycle, I suggest resetting your appliance, by shutting the power off at your home's circuit breaker, for 3-5 minutes. Once power is restored, you will need to set the clock before starting any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
The oven heats up but stops a 200 degress
Good Afternoon Ben,
I see that you are having trouble with your dual fuel range, model# PLCF489AC, heating up past 200 degrees. It sounds like it could possibly be something to do with your control board or your oven thermostat. I suggest giving your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for at least 2-3 minutes. When power is restored to your range, if it still will not heat up past 200 degrees, I suggest you contact your local authorized technician. I hope this is helpful.
-Best Regards-
WP
Apr 18, 2014 | Frigidaire PLCF489AC Dual Fuel (Electric...
My Whirlpool AKZ451/IX/01 will not heat up correctly
I can fix this for you. Where are you residing please? Thanks David. "The Famous Forry'
Oct 20, 2017 | Philips Ovens
Hi..if i set the control knob to 350 for the oven..its goes to 400 or 450 degress..i put a oven termonater in there..its always hotter than what u set it on. model # JBP24G0K2AD or the o is a 0 not sure..
The oven thermostst needs replacing, as it is not sensing the correct temperature, this is the switch behind the control knob
Please rate my solution.
Thanks.
Nov 10, 2009 | GE Ovens
Getting F4 error
I dislike new electronically contolled ovens so much. Electronics are never meant to be near temperatures reaching more then 200 degress.
F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor
Aug 01, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Loud, vibrating noise when turned on that lasts until it reaches 350 degress
Sounds like the oven fan is loose or there is a large build up of burt material on the fan making unbalanced
Jun 09, 2009 | Ovens
Frigidaire PLCF489AC Dual Fuel (Electric and Gas) Kitchen Range Logo
73 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
