Question about Whirlpool Duet GHW9150P Front Load Washer
Not enough water per load and suds
The cloths get wet barely but there is no water in the drum
should there be water visible on the door? I also use small amounts of HE soap but it seems to accumulate inside and when I use the clean washer feature it suds like crazy and comes out the back top!
  • 32 Answers
If you use washer without cloth you will some water and it is normal..use different detergent and use less you will be ok..hope that help you.
Posted on Jun 24, 2009
Hoover washer dryer - not sure it is filling with enough water
How old is the machine and which wash cycle are you selecting? Newer machines use very little water; it is not needed.
Mar 08, 2014 | Dryers
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
Does not clean clothes properly/suds still visible on door at cycle end.should i be able to see a water level on door during cycle non visible at present. Thanks Alan
don't know about water level on side door machines but do know that most people put way to much detergent in with their clothes and frequently then see soap suds in rinse is there is too much detergent.
Apr 02, 2011 | Washing Machines
Doesnt seem to be cleaning good. should i not be putting so many clothes in it? should I use more soap? I feel like the clothes barely get wet!
These washers use very little water. (about 2 inches in the bottom of the wash tub) The actual amount used will vary based on the volume of clothes and the type. (snythetic clothes do not absorb much water, but put in a load of cotton towels, for example, and the clothes absorb the water, causing the water level to drop, and the machine will add more water to return the level to the set point, which usually takes a several short fills, over a couple minutes)
To see that the clothes are indeed wet, just pause the machine a few minutes into the cycle. The door will unlock, and you can feel how wet they are. When the cycle completes, these machines spin so much faster (about twice as fast as most top loading machines) that the clothes feel very dry. (thus reduced drying time, and additional energy savings) Because of the lower water usage (about 12 gallons vs. about 45 for a top loader) make sure you only use 1 to 2 (max) tablespoons of HE detergent per cycle, and only 1 teaspoon of fabric softner if you use it. (don't use fabric softner on towels) Using too much addatives will cause odor issues, and possible performance issues.
Sep 03, 2009 | LG WM-1832C Front Load Washer
Water level too low. clother wet. No water visible or suds. What is wrong.
Your expectations are based on top load washers.
Front load washers use only a very little water, and suds are an enemy. (HE soaps are designed to clean without suds. Suds are really for show and cause drag on the wash tub during spin.) If you start a load with no clothes, you will see that the water level never gets above a couple inches in the tub. That is the correct water level for front loading machines. PS. Because of the low water use, make sure you use very little soap. (one to two tablespoons per load only!)
Aug 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Not enough water per load the cloths get wet but there is no water floating in the drum should there be water visible on the door?
not really...that's the point of these washers..low water usage. the clothes fall into a small puddle in the bottom over and over and rinse often.
Jun 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Can you adjust the water level on the LG Tromm WM1814CW? The water level when washing and rinsing is so low that the clothes are barely wet when the washer has finished.
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Mar 29, 2009 | LG WM1814CW Front Load Washer
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Water level
The level of water in the drum is controlled by a pressure switch. This switch is attatched to the drum via an air tube which pushes air into the pressure switch as the machine fills with water. There could be a blockage in the pressure chamber attatched to the drum or the pressure switch is faulty.
Oct 31, 2007 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
107 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
