Question about Brother Entrepreneur Pr 650 Embroidery Machine With Hoops & Frames
Automatic needle threader misses the eye of needle 3 what is the fix.
  • Brother Master
  • 1,388 Answers
Usually, the needle needs to be raised so the needle eye will match the threader. However, perhaps your threader has been bent or inadvertently pushed up or out of position.
Jun 06, 2017 | Sewing Machines
I have a Babylock BMP9 6 needle embroidery machine. The automatic needle threader mechanism is not dropping down far enough to use to thread the needles. Any suggestions on how to fix this?
On older machines that do not have the automatic needle-up feature, the user needs to manually adjust the needle height so the threader will match the needle eye.
Oct 29, 2016 | Sewing Machines
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
There's nothing wrong with the Threader, it's just that the Threader doesn't reach the back of the Needle!
Usually you have to manually move the needle up and down until its height matches the threader height. Newer machines have an automatic needle stop that generally matches the threader but most older machines need to be manually manipulated.
HINT: If you do need to manually thread your needle, lick your index finger and then rub the back of the needle's eye. Your thread will literally "leap" through the eye! This works for hand-sewing needles too!
Feb 03, 2016 | Singer 8763 Curvy
My automatic needle threader doesnt line up with the eye of the needle
possibly the wrong needle length then . have never needed one myself .
Sep 24, 2015 | Sewing Machines
Needle threader not threading
1. LOOK TO SEE IF YOU HAVE THE WIRE HOOK ON THE THREADER. THIS IS A VERY SMALL WIRE THAT GOES THROUGH THE EYE OF A NEEDLE. 2. IF IT IS MISSING THEN UNSNAP THE OLD ONE AND REPLACE IT. 3. CHECK TO ENSURE THE NEEDLE IS AT IT'S HIGHEST POINT. 4. LOOK CAREFULLY TO SEE WHERE THE WIRE HOOK IS GOING TO (TOO HIGH OR LOW). 5. ADJUST THE THREADER UP OR DOWN TO CAUSE THE WIRE THREADER TO GO THROUGH THE NEEDLE EYE. ADJUSTING IS DIFFERENT FOR EACH MACHINE BUT YOUR USER'S MANUAL SHOULD HAVE THIS. ALSO, YOU CAN USUALLY FIND THIS ON YOU TUBE.
Jan 31, 2015 | Sewing Machines
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
Needle threader misses eye of needle 3, how can this be fixed
There is a small wire hook that, when utilized, pokes through the eye of the needle. Several issues can occur. 1) Wire is bent slightly (use fingernail to move the wire to realign with needle) 2) hook is broken on wire (repair shop) 3) needle not fully inserted in slot
Apr 18, 2014 | Brother Entrepreneur Pr 650 Embroidery...
Needle threader doesnt work
it would probably be better to take the machine to a sewing machine
shop & have it done.
my needle threader is attached to the needle threader bar inside the machine & I imagine your is too.
Apr 26, 2012 | Sewing Machines
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Brother Entrepreneur Pr 650 Embroidery Machine With Hoops & Frames Logo
106 people viewed this question
Top Brother Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Marion Ravendel
Marion Ravendel
Level 1 Expert
Are you a Brother Craft and Hobby Expert? Answer questions, earn points and help others
